Am I missing something? why get a 450 over 350?
Am I missing something? What incentive do you have to get the f450 over the f350 crew cab 8ft bed drw 4x4? The tow capacity for the 450 is only 1200lbs more as opposed to last year where is was like 5000lbs more(I think?) Payload from what I have seen has no real advantage ether. Why not go with the f350 and save almost 4k for an equal trim truck? or are they saying 1200lbs is worth 4 grand now? Are there some unseen advantages of the f450?
For me, the main benefit (and it's a big one) is the wide track axle. I'm sure the 19.5 tires are nice, but the 17" tires have many more choices and cost a lot less. If I end up with a dually, it will most likely be a F450. There are several down sides though
The other down sides are
1. 500# more weight, which means 500# less payload (on paper) and slightly slower acceleration and braking.
2. Much of that 500# weight gain is unsprung, which will likely degrade ride quality.
3. Ford's TPMS doesn't work with the 19.5" tire construction yet, so no TPMS for the truck.
4. The 19.5" tires need to be inflated in a cage or with a remote fill as they can be deadly if they fail.
5. Insurance is often more, sometimes, much more
6. Lower MPG due to the 4.30, though it is a great towing gear
7. It costs over (edit) $3k more
Well, I was set on a f450, but after making that list, I need to rethink the f350 if a dually is needed.
7. It costs over $4k more
Well, I was set on a f450, but after making that list, I need to rethink the f350 if a dully is needed.
Not quite sure why the 19.5" need to be inflated in a cage. They ARE NOT split rims. They were done away with years ago. Any tire can be dangerous.
After market TPMS work just fine on the 19.5" Most of us who will tow with our F450's have them for the truck and the trailer.
bigdon68
9' smaller turning circle is important when backing into a parking spot (most single-spots are tight for a 22' long 8' wide truck) and positioning a trailer. It let's you start turns later to help with trailer off-tracking, and allows more options for u-turns.
Frantz, if I want a platinum 6.7 4x4 and will have ~3650# total payload (passengers + pin with a 41' 14K fifth wheel - weekend use) and would like to drive it nearly every day, would you recommend a F350 SRW, F350 DRW or F450?
