I wish my excursion...
Old Sep 17, 2016 | 07:41 AM
Magnus E's Avatar
Magnus E
Mod I want and can afford: powerfold and power extend mirrors
Mod I will never do but would want: full on zombie masher with built in flame thrower
What I wish I could change: if somehow it could be a new 2017 all aluminum superduty platinum with the 6.7 ... but an Excursion.
Old Sep 17, 2016 | 09:28 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Mod I need to get around to
Hook up the overhead DVD monitor.
Revalve my rear shocks.
One mod I'll probably never do
I'd like to 4 link the rear suspension by grafting on a 2015 dodge 2500 frame.
Old Sep 17, 2016 | 10:37 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Mod that I can afford and will do at some point
S369sxe, studs, and complete fuel system revamp. Cuz who doesn't need a 600hp/1300tq daily driver
Mod that I will never do but would love
2015 front, rear quarters, and interior swap plus coil front end.
What I wish I could change about my EX
Should've pulled the fresh coat of undercoating off when shopping. Ended up with rust that was hidden, it is what it is now.
Old Sep 17, 2016 | 04:13 PM
mecdac's Avatar
mecdac
Question
Interesting...@pirate4x4_camohave you already done the coil over front?
Is this just for handling/off-road articulation/general comfort?
And you would like to do the frame and not just the rear drive assembly?
Old Sep 17, 2016 | 05:38 PM
pirate4x4_camo
Originally Posted by mecdac
Interesting...[utagt]pirate4x4_camo[/utag]have you already done the coil over front?
A few years back I switched the front to coilovers and a 4 link setup from Fabtech.
Id like to link the rear "just because". No legit reason for it as the leafs work fine-ish. just something to do if I run across a totaled Ram truck I guess. ( it would give me a good reason to pull the cab off and build a full rollcage is about the best excuse I can come up with to justify the effort.
my front coilover and 4 link setup with hydraulic bump stops
Old Sep 17, 2016 | 05:47 PM
pirate4x4_camo
Dodge did a good job on the rear frame incorporating the link mounts and getting the geometry dialed in. but since my ride height is considerably higher then the Ram I would likely have to modify it anyhow.
I haven't crawled under one with a tape measure to verify but this would more then likely be the way to go. I was mostly just impressed with frame setup on the Ram when I saw it.
Building custom mounts to make the rear axle work looks doable enough.
Old Sep 17, 2016 | 06:57 PM
mecdac's Avatar
mecdac
So it's a geometry thing, thanks.
Old Sep 17, 2016 | 07:13 PM
pirate4x4_camo
Yes, specifically Roll center and anti squat.
Old Sep 17, 2016 | 07:27 PM
gots_a_sol's Avatar
gots_a_sol
Mod I REALLY want:
A trans with more gear options. The 5 speed manual is nice but the gaps are a bit annoying since the cummins isn't a revver like the v10. A 7 or 10 speed would be great.
Mod I want but won't get any time soon:
2012+ front end. Maybe if I have to replace the rear quarters for some reason.
Thing I would change about my rig:
Other than the trans, I'm pretty happy with it.
Old Sep 17, 2016 | 08:58 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Mod that I can afford and will do at some point I will most liekly redo the interior at some point. That is the only other thing i can think i still need to do at this point
I have to agree with tom on the CABT conversion. That and bullet/bomb proof it.
I really hate how much i have invested in it now.
Old Sep 17, 2016 | 11:29 PM
wpnaes's Avatar
wpnaes
1. Roof rack.
2. 2020 F250 front conversion.
3. More patina and sagebrush pinstriping.
Old Sep 18, 2016 | 01:26 PM
Atc210's Avatar
Atc210
Mod that I can affordand will do at some point
4.10 gears and TrueTrac locker/Winch
Turn it into mini version Dead Reckoning (From Land of the Dead)
Would love for the cabin to be as quiet as the newer SUV’sand more gears in the transmission.
Old Sep 18, 2016 | 04:09 PM
  #28
BigBlueX's Avatar
BigBlueX
1. ARP studs with upgraded turbo.
2. Cummins 24v swap or front coil suspension upgrade
3. Harley Davidson full interior
Old Sep 18, 2016 | 09:31 PM
  #29
Apocalypse's Avatar
Apocalypse
Originally Posted by Atc210
Mod that I will never do but would love[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Turn it into mini version Dead Reckoning (From Land of the Dead)
Ask and ye shall receive!
https://www.ford-trucks.com/forums/1...rig-build.html
Much easier to do than you thought huh?
Old Sep 18, 2016 | 11:24 PM
  #30
RBerry9511's Avatar
RBerry9511
1. 08 mirrors, x/b springs, roof rack, moose knuckle sandwich front bumper.
2. 2015 front end swap.
3. 2nd row captains chairs
And thanks Apoc for starting this thread.
