Reviving an Excursion!
Old Sep 29, 2016 | 12:08 AM
  #61
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Double post
Old Sep 29, 2016 | 06:42 AM
  #62
fordboy2's Avatar
fordboy2
What's left to do yet?
Old Sep 29, 2016 | 11:04 AM
  #63
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Just some nagging things that take a little time.
Wet sand and Buff the new paint and remove the pin stripe then wax
Replace a coil that is giving a miss (got worse after cleaning under the hood)
Find and install the underhood light, somehow lost it in the garage
Drivers side arm rest, need to swap the cover with the passenger side so the top is in better shape
Fix or remove a loose heat shield on the tailpipe
Otherwise she should be ready to go soon, but i'd say I have another 8 hours or so of work before it's finished.
Old Sep 29, 2016 | 11:47 PM
  #64
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
The Miss is fixed, new motorcraft coil runs so smooth now.
Fender trim is mounted for good
Bumper is mounted and not tweaked anymore, lower plastic is secure.
This was before I washed the windshield
Old Oct 1, 2016 | 08:06 AM
  #65
ExxWhy's Avatar
ExxWhy
Nice job Russ, that was a lot of work but I believe you have rescued it.
Old Oct 1, 2016 | 09:31 AM
  #66
CharlyG's Avatar
CharlyG
Beavo!
ha!
I meant Bravo but had a typo, or???
Old Oct 2, 2016 | 07:54 PM
  #67
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
DONE!
It gets a remote start installed tomorrow, then it will be listed for sale Monday evening.
I'm pretty proud of how it turned out. Been a good bit of work and cash but I'm happy it'll be back on the road again for many miles to come I hope.
The damn hood light! installed and working.
I had an extra overhead console with working temp/trip/mpg so I swapped that out.
Had to get some shots of them together
Old Oct 2, 2016 | 07:58 PM
  #68
agsmv1's Avatar
agsmv1
Looks great! Good luck on the sale.
Old Oct 2, 2016 | 08:41 PM
  #69
WE3ZS's Avatar
WE3ZS
Looks great Russ, nice job!
Good luck with the sale.
Old Oct 2, 2016 | 08:43 PM
  #70
Misky6.0's Avatar
Misky6.0
Does it have a "CK SUSP" label bottom right of instrument panel, just below battery icon??
Old Oct 2, 2016 | 10:34 PM
  #71
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Thanks guys, I think it should move by the end of the week..fingers crossed.
I've never seen an Excursion with the "CK SUSP" like the 2005 guys are seeing. Neither of mine 2000 with the older cluster or my 2002 with the newer cluster. I've seen it on Explorers and Expeditions with the air suspension.
Spoke with the seller of the truck, his friend made the old CL posting and he's out gold mining right now, he's going to try and have it removed tomorrow though.
Old Oct 3, 2016 | 01:01 AM
  #72
ranagent's Avatar
ranagent
If everybody here hits "prohibited" on that old ad it will be gone in no time, no harm to anyone.
Old Oct 3, 2016 | 06:34 AM
  #73
1 Excursion camper's Avatar
1 Excursion camper
Looks great! good luck on the sale!
Old Oct 3, 2016 | 06:47 AM
  #74
mecdac's Avatar
mecdac
Wink
Only issue is the license plate will match, I still need to get in contact with the guy and see if he'll pull it down. Otherwise I can go get new plates for $10.
It's getting close, I doubt if I'll make my deadline of having it listed by the 30th though...few little nagging things that will require a little more time.
Put some plates on it that state "80 MPG"
Nice work, on time and hopefully under budget.
Old Oct 3, 2016 | 08:03 AM
  #75
Greenscobie86's Avatar
Greenscobie86
Came out nice man! Are you going to remove the pinstripe on the pass side too?
Definitely a quick turn around.
