Aerostar Ford Aerostar
air conditioning
Old Aug 21, 2003 | 11:30 AM
Pagemaker's Avatar
Pagemaker
air conditioning
Question,
what causes an air conditioner to work fine when going down the hyw, but blows warm air when you are setting in traffic or idling?
I also noticed that my compressor makes allot of noise.
Old Aug 22, 2003 | 07:26 PM
Timothyap5vm's Avatar
Timothyap5vm
air conditioning
Obiously the compressor is wearing out and needs extra speed to make the cool air. Try to find a good working one at a junkyard.
You might want to check out the thread "is water pump replacement an easy job?" to find help as the A/C compressor is near the water pump.
https://www.ford-trucks.com/forums/s...threadid=27779
Good luck!
Old Aug 25, 2003 | 02:27 PM
Mikeman's Avatar
Mikeman
air conditioning
If the compressor is OK, there is the possibility that the fan clutch is bad. When you are driving down the highway, enough air flows across the condenser that adequate heat is removed from the refrigerant without the fan. Also, make sure there are not a lot of bugs, leaves, etc. plugging up the condenser.
Old Aug 26, 2003 | 10:02 AM
aerocolorado's Avatar
aerocolorado
air conditioning
Go with Mikeman's suggestions - bad fan clutch. The noise is likely the result of high pressure buildup in the compressor due to restricted air flow.
Old Sep 8, 2003 | 08:24 PM
LouMc's Avatar
LouMc
air conditioning
Definitely a bad fan clutch. Just put a flex fan on mine for the same reason.
