Moon roof
Old Sep 16, 2016 | 07:10 AM
Rasalas's Avatar
Rasalas
Originally Posted by J-MAN8880
The hard top on my Rubicon leaks so bad, a couple drips would be a welcome surprise!
Going back 25 years I have known of the removeable hardtops leaking. I think it is inherit to the design. My friend had his back to the dealer several times and the water still ran down the inside of the windshield and the unsightly layers of caulk built up deeper and deeper. He finally cleaned it all up and fixed it himself but the roof would never be able to be taken off again with the silicon holding everything together.
Old Sep 16, 2016 | 07:33 AM
JeepPuller's Avatar
JeepPuller
Don't take this the wrong way, but it is a Jeep.
On the original topic... this is exactly the reason I searched for a 250 without a moon roof.
Old Sep 16, 2016 | 08:49 AM
69cj's Avatar
69cj
No leaks at all, knock on wood, on my 2015.
Old Sep 16, 2016 | 09:41 AM
SESWIM's Avatar
SESWIM
Try pushing up on the sunroof when going through the car wash. The pressure pushes down on the roof letting some water in. My daughters Range Rover is really bad about it. Just push up on it and it stops. Some cars are worse than others. The European cars seem worse.
Sam
Old Sep 16, 2016 | 09:47 AM
Rasalas's Avatar
Rasalas
Run it through the car wash then open it up and see if the drip tray is dry. You might be surprised, or you might have an exceptional one.
Old Sep 23, 2016 | 09:25 AM
finchturf's Avatar
finchturf
Anyone else noticed this yet? I put blue tape around it and at one car wash seemed to solve the problem... Today it blew most of the tape off and water was coming through the overhead console... No Bueno. Got my dealer looking into any bulletins - but I'm sure there is nothing as of yet. Just don't want them disassembling the entire roof - it never is the same when stuff like that happens. Sucks.
Old Sep 23, 2016 | 09:35 AM
EpicCowlick's Avatar
EpicCowlick
Have you tried pushing up on the glass while going through the wash?
Old Sep 23, 2016 | 09:54 AM
finchturf's Avatar
finchturf
Have not. That'll be my next option! I typically don't ride it through...
Old Sep 23, 2016 | 10:01 AM
EpicCowlick
You'd have to give up your cup of Joe while you watch your baby getting pampered! Seriously, this sounds like something everyone is going to have to deal with unless a solution is found.
Old Sep 23, 2016 | 11:07 AM
Rasalas's Avatar
Rasalas
Make sure that water does not run across the headliner and down the corner post. Maybe it has changed by now but I just had a new windshield put in (2nd in 16 years) due to water getting into the roof framework and running down the corner post and right onto the PCM. After a rain the truck became possessed andI would come out to the heater on, dome light on, loud buzzer under the dash and if not caught early, dead battery. Sometimes the radio, sometimes no speedometer, key in ignition chime even without the key and a flashing OD button indicated transmission fault and a check engine soon light. All without the key. First episode 10 years ago cost $500 in research and no results since it always stops after a day or so. Finally stone in windshield and it didn't come back until a couple of months ago.
Lesson learned: be careful of water in the cabin where it is not supposed to be. With today's reliance on computers (ECM, PCM) everything could be in jeopardy if that water migrates farther.
Old Sep 23, 2016 | 03:18 PM
HDKING's Avatar
HDKING
I have a 2015 F150 Platinum and typically go through an automated car wash at least once a month and have not had any leaks.
Old Sep 23, 2016 | 03:46 PM
Robmiezer's Avatar
Robmiezer
Originally Posted by EightySecond
I can pressure wash the windows on my house, the door on my wife's Benz, and make them all leak. Does that mean they were made by Ford's moonroof manufacturer????
Come on guys.
Have to agree... Don't put a high presure nozzle 3" away from your window seals and expect nothing to get through. It happened a couple timnes in my 06 Eclipse with moon roof; it may not have sealed well enough when closed and went through wash. Though I too will be afraid to drive this beast through a normal drive through (looks like I will be visiting the local Truck wash often ).
Old Sep 23, 2016 | 06:15 PM
  #28
Rutcutter's Avatar
Rutcutter
I guess I got a good one,just went threw the high pressure wash here in town and yes my truck barely still fits in thank goodness. Mine didn't leak at all and I was crawling all over looking..
I would take it in and have them look at it..
Old Sep 23, 2016 | 08:57 PM
  #29
toddstang's Avatar
toddstang
Sounds like the run off/ drain tube might be bound up or clogged.
The dealer should check that first.
Old Sep 23, 2016 | 11:39 PM
  #30
Jace2016's Avatar
Jace2016
Why does everyone seem to think this is OK? You can tell by the responses its a common problem. "Gotta hold 1 hand up against the glass, and the other on the antennae...." WTF really people? Ford can build an awesome truck putting out 440hp/925 lb/ft torque and demand 80 grand for it but can't seem to stop a moonroof from leaking water at a car wash? I understand if the guy was standing there with a pressure washer against the seals but a freakin automated car wash? Those things don't spray the same spot for longer than a millisecond at best. Im discouraged and unfortunately my package its standard as well and will never be opened except by the dealer who has to stop the water from leaking through it! I guess I should just silicone it shut so it won't leak eh? NO! FORD FIX THIS!
....Im wrapping the roof in saran wrap thats it, problem solved.....
