Whining Noise
Old Sep 15, 2016 | 11:13 AM
mtntop1's Avatar
mtntop1
Whining Noise
For the past two years I have had this whining noise coming from under the hood 95 F150 5.0L E04D auto trans .It started after I changed the cam and put shorty headers on.The sound doesn't change when the trans is shifting gears.It only happens with the engine under load and gets louder as the rpm's increase.It won't do it in neutral only when driving.I changed the Alt,water pump,smog pump,power steering pump,idler's,serp.belt.Yesterday I dropped the trans pan no debris and fluild was clean ,only a little black goop on the magnet which is normal.
Old Sep 15, 2016 | 06:36 PM
justcruzin125's Avatar
justcruzin125
Does it whine when in park and not moving?
Old Sep 15, 2016 | 09:45 PM
mtntop1's Avatar
mtntop1
No just when moving and it starts at about 20mph
Old Sep 15, 2016 | 11:30 PM
justcruzin125
So probably something in your transmission or rear axle
Old Sep 16, 2016 | 08:57 AM
mtntop1's Avatar
mtntop1
I am kind of thinking it's not the trans.The pitch of the whine is the same in all gears.
Old Sep 16, 2016 | 02:57 PM
DieselCamper's Avatar
DieselCamper
Diff whine? I had it in my '08. Roll your window down and go 20 MPH or so and check if you hear it. Maybe your diff is low on fluid?
Leemakesmepee
Oct 23, 2011 10:31 PM
ss3964spd
Mar 5, 2007 08:44 AM
Ford Fx4
1997 - 2003 F150
May 4, 2006 12:32 PM
King1of3
Jan 16, 2003 01:43 AM
sweet82
Aug 2, 2002 03:22 PM
