Help, my truck keeps shredding rag joints...
Old 09-15-2016, 10:51 AM
HooniverseJeff's Avatar
HooniverseJeff
HooniverseJeff is offline
I've gone through two in 6 months.
Clearly something is wrong besides the coupler itself, no? I'm assuming I need to check column alignment and a number of other things.
Any tips/advice to help sort this out?
<blockquote class="instagram-media" data-instgrm-captioned data-instgrm-version="7"><div style="padding:8px;"> <div style=" background:#F8F8F8; line-height:0; margin-top:40px; padding:50.0% 0; text-align:center; width:100%;"> <div style=" background:url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACwAAAAsCAMAAAA pWqozAAAABGdBTUEAALGPC/xhBQAAAAFzUkdCAK7OHOkAAAAMUExURczMzPf399fX1+bm5mzY 9AMAAADiSURBVDjLvZXbEsMgCES5/P8/t9FuRVCRmU73JWlzosgSIIZURCjo/ad+EQJJB4Hv8BFt+IDpQoCx1wjOSBFhh2XssxEIYn3ulI/6MNReE07UIWJEv8UEOWDS88LY97kqyTliJKKtuYBbruAyVh5wO HiXmpi5we58Ek028czwyuQdLKPG1Bkb4NnM+VeAnfHqn1k4+GP T6uGQcvu2h2OVuIf/gWUFyy8OWEpdyZSa3aVCqpVoVvzZZ2VTnn2wU8qzVjDDetO90G Sy9mVLqtgYSy231MxrY6I2gGqjrTY0L8fxCxfCBbhWrsYYAAAA AElFTkSuQmCC); display:block; height:44px; margin:0 auto -44px; position:relative; top:-22px; width:44px;"></div></div> <p style=" margin:8px 0 0 0; padding:0 4px;"> <a href="https://www.instagram.com/p/BKOQ9mdBpfs/" style=" color:#000; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none; word-wrap:break-word;" target="_blank">Again? Seriously? #HoonTruck hates rag joints... Not very #HooniverseThings #Ford #F100 #Truck</a></p> <p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;">A photo posted by hooniversejeff (@hooniversejeff) on Sep 11, 2016 at 9:47am PDT</p></div></blockquote>
Thanks!
Old 09-15-2016, 10:52 AM
HooniverseJeff
Instagram embed's don't work?
Here's a pic:
Old 09-15-2016, 10:57 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
What are you replacing, the entire steel/rubber coupler or just its rubber piece?
Old 09-15-2016, 11:00 AM
HooniverseJeff
The entire coupler.
Old 09-15-2016, 11:09 AM
NumberDummy
Originally Posted by HooniverseJeff
The entire coupler.
Where the heck did you buy this crap?
No wonder the coupling is breaking apart (shredding)...this is NOT correct. No steering coupler prior to 1980 had a nylon or plastic section...it's supposed to be rubber.
C5TZ-3A525-A .. Steel/Rubber Steering Coupler / Obsolete
1965 F100/250 2WD / 1966 F100/250 2WD before serial number 900,001.
RPN PARTS in Erie PA has 1 = 888-864-9305.
FRIESEN FORD in Aurora NE has 1 = 402-694-3111.
HASELDEN BROTHERS in Hemingway SC has 1 = 843-558-2134.
GREEN SALES CO. in Cincinnati OH has 39 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 519 = 800-4576-9653.
Old 09-15-2016, 11:10 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Maybe it's just the perspective of the angle of the picture, but the flange at the end of the steering shaft looks like it is bent. Could that be the case? I can get you a picture of just the shaft showing the flange if you'd like. It does have some contour to it, so that might be all I'm seeing.
Those new rag joints are using a plastic/nylon insert. Dennis Carpenter, et al.
Old 09-15-2016, 11:11 AM
HooniverseJeff
No wonder the coupling is shredding...this is NOT correct. No steering coupler prior to 1980 had a nylon or plastic section...it's supposed to be rubber.
C5TZ-3A525-A .. Steering Coupler / Obsolete
1965 F100/250 2WD / 1966 F100/250 2WD before serial num,ber 900,001.
Oh...
Oh Oh O'Reilys!
Ok, time to order the correct one. Thanks ND
Old 09-15-2016, 11:12 AM
HooniverseJeff
Easier than a phone number... I just copied and pasted that part number into Amazon. Is this the correct coupler I should be using instead?
https://www.amazon.com/C5TZ3A525A-St.../dp/B015P4LV9Y
Old 09-15-2016, 11:15 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
That looks better to me from the picture. I called Green Sales about one quite some time ago and even then they were selling only the reproductions made by Dennis Carpenter.
Old 09-15-2016, 11:17 AM
HooniverseJeff
It definitely looks more robust. We'll see when it gets here... unfortunately it wasn't available for Amazon Prime, haha.
Now I have the crappy one sitting in my garage. Maybe I'll make it into a $30 beverage holder...
Old 09-15-2016, 11:20 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Here's the reproduction from Carpenter. Looks like the nylon to me here, too.
Steering Gear Input Shaft Coupling | Dennis Carpenter Ford Restoration Parts
Old 09-15-2016, 11:26 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
I was looking at the broken coupling in your picture some more - that must be a thrill when it lets go, depending on what you are doing at the time.
Old 09-15-2016, 12:23 PM
'65Ford's Avatar
'65Ford
'65Ford is offline
I've used a plastic one, like the one in the picture from Carpentar, for about 10 years and 40,000 miles. Maybe you got a bad one or I got a good one or you have something else going on. I keep a spare (original type material) in the glove box just in case.
Old 09-15-2016, 12:55 PM
HooniverseJeff
I'll keep the nylon as a spare in the truck, good call.
Yeah I think there might be something else going on as well.
Old 09-15-2016, 12:57 PM
HooniverseJeff
Thankfully I was only about a mile from home and it was mostly a straight drive. Definitely exciting though.
There's a 65 or 66 for sale on the street around the corner from me right now... Looks to be in rough shape, and they're asking $1800.
Quick Reply: Help, my truck keeps shredding rag joints...
