I red ford says no WEight Distribution hitch needed while towing. I find this hard to believe, especially passing trucks or on a windy gusty day.
I know on the side of caution would be a good idea, but I would like factual information if you can assist. My 2011 had anti sway as well...same thing?
Technically the weight distribution is "not" needed due to the fact the hitch goes so far into the frame. That said, we had several people on here smarter then me that said they would still run it on any trailer heavier then 5K lbs.
I am going to use my Equalizer hitch with 10K bars to help with sway, and keeping it directly behind me. Going to try to get it setup this weekend.
Sway control and weight distribution are NOT the same thing. Ford says you don't need WD due to the strength of the hitch.
With a 25' Airstream pulled by a Super Duty, I would see no need for sway control. However, it's not a big deal to use it if you already have it, so if it makes you feel more comfortable, go for it!
I do agree with you. For sway you need a sway control bar. When I was pulling a tag along trailer I used the Equal-i-zer brand hitch it had both incorporated in it and worked great.
Everything I have read about Ford intergrating the hitch into the frame (for 2017 its not a bolt on hitch) so we don't need WD hitch or sway control. I am going to try it and see if there is a difference.
My question is? What is YOUR hitch rated at? W/D or not. They have different ratings if you are NOT using the bars. Or are you getting a new 3" hitch properly rated for the tongue weight and trailer weight
My 2011 sagged just like that....but my tongue weight was 1119 on my TT as it was a front slide (4 slides total). Even sagged with my Equalizer hitch. I recently sold it so I won't be able to see how it does on my '17. I'm downsizing to a smaller camper next Spring and probably won't even need the Equalizer on it. Shoot....my crew golf cart on my '12 tandem sagged the back of my '11 F250. I think two bags of ice in a cooler drops it down to the bump stops......LOL...LOL
Whether it can keep the sway under control electronically or not would not be my concern, nor the hitches capability of carrying the weight, I like a WD hitch to help with the squat which is putting some weight on your front tires at the same time. No reason to carry all the weight behind the rear axle and put all the stress on the rear tires, let the front help out some too.
Need it? No. Will it give you a better towing experience? Absolutely. Transferring some weight to the front axle will give you a safer and more relaxed towing experience. The same applies to sway control. The best easiest system to install and use that does both is the Equalizer E4. The Reese Dual Cam as mentioned above works just as well but is more expensive and much more difficult to dial in.
All that said, the easiest way to decided if you want (as said, you don't need) WD/SC is to do your first tow without it. The truck is rated to handle it so give it a try. If you feel completely comfortable in all situations, you just saved yourself $450. If not, RV Wholesalers parts dept. is generally the cheapest on the E4 system I mentioned.
I agree with this comment, BUT, proper weight distribution can do a lot to reduce or eliminate sway. The other way to say this is that a poorly distributed load can CREATE sway.
And, from what I've seen, most hitches that have sway control features, also happen to have weight distribution features.
My two cents, or three up here in Canada due to the exchange, is that a WDH is helpful, even when it's not needed. A little time spent at the CAT scales convinced me that pretty firmly. No matter how that new Ford hitch is attached, it can't put weight ONTO the front tires of the truck, but a WDH can.
