Replace 3rd brake light unit?
Old Sep 13, 2016 | 12:22 PM
Pele's Avatar
Pele
Is the Excursion 3rd brake light from the F250/350 pickups like the rest of the truck... Or is it from an E-Series van like the tail lights?
In either case, is there a unit that has both the brake light and a bed/cargo area light? My rear window is tinted and I'd like to put a little light up high while I'm backing up... Just a little.
I really don't want to drill a bunch of holes for auxillary lighting, especially up high.
Old Sep 13, 2016 | 02:00 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
It's actually from neither, the closest 3rd brake light that will kind of work on it is from the 1997-2003 F-150. But it still does not fit correctly, so it would seem the Excursion 3rd brake like is specific to the Excursion only.
Old Sep 14, 2016 | 07:58 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Russ is on point, one of the parts that is body specific is our third brake light. It's contoured for the top of the rear hatch, which is why nothing else just bolts in its place and looks clean. The F150 one is quite unsightly IMHO, pretty trashy.
Why not just wire in a cheap LED light or two over the hitch and run wires to the reverse lights? With such low current draw they won't hurt anything. Hell even a 3-watt Cree or something by itself throws a good bit of light itself.
Old Sep 14, 2016 | 08:13 PM
Pele's Avatar
Pele
Well crap. I wanted it lit up top and aimed downward. I have LED floodlights to mount under the bumper. I guess I'm going to have to aim them upwards.
Old Sep 14, 2016 | 08:18 PM
Krazee Matt
Veteran: Navy
Don't underestimate the power of an LED flood, they'll huck some light. Some cheap Velcro works for me when I'm figuring placement for maximum useable light and aiming.
Or you could go crazy and get some of the flush mounts and put them inside the barn doors right by a hinge on the corner
Old Sep 14, 2016 | 08:41 PM
Pele's Avatar
Pele
They're actually magnetic base lights salvaged from some industrial Trane brand air handlers. I have a couple different styles. I'll post up some part numbers later.
Old Sep 14, 2016 | 09:43 PM
DOOM173's Avatar
DOOM173
Can you even still get OEM 3rd brake lights from the dealer anymore?
Old Sep 14, 2016 | 10:29 PM
breezy5000's Avatar
breezy5000
YC3Z13A613AA $165 @ Tasca Ford
Old Sep 15, 2016 | 12:50 PM
jpr38057's Avatar
jpr38057
It is obsolete from Ford but there are a few dealers out there that still have them (Tasca is not one of them).
pye
Mar 10, 2007 12:56 AM
kc7smo
Electrical Systems/Wiring
Mar 14, 2006 11:52 PM
broncobillyII86
Bronco II
Mar 10, 2006 07:01 PM
classyfish
Mar 7, 2006 08:52 AM
MemOrex
Jan 4, 2005 10:15 PM
