Rebuild so far GREEN MACHINE
Old Sep 13, 2016 | 10:13 AM
greenmachine86's Avatar
greenmachine86
OK all rebuild is coming along and thank you for all the help you have been to date this is what has been done/replaced.
New Battery
New Starter
New Starter Relay
New wiring from battery to starter etc
New plugs and wires
New Ignition coil
New Brakes springs and wheel cylinders
New Shift Finger and new pads for shift forks
New Ebrake cables and return spring
New headlight switch
New Valve cover, oil pan, Transmission top gaskets
Add ons
Clearance lights
Fog lights
Stereo
Air Horn
On order
New weather seal kit for door windows etc
Immediate needs
Steering column
Wiring Harness
Battery box/Mount
Stick shift boot seal
Any advice on anything Else I need to go over thoroughly to make sure she is mechanically sound?
Old Sep 13, 2016 | 01:33 PM
FuzzFace2's Avatar
FuzzFace2
Did you change the axle(s) oil?
I am sure once on the road you will find other things.
Dave - - - -
Old Sep 16, 2016 | 12:38 PM
greenmachine86
LOL yes I did change the oil but have a constant leak out of the back of my valve cover I am thinking its only cause whoever was in there last broke off a bolt towards the back of the cover and just left it like that any good hunts on getting it drilled back out? I bought a easy out kit but cant get the bit to bite into the stud
Old Sep 16, 2016 | 01:39 PM
FuzzFace2's Avatar
FuzzFace2
Using a reversing drill bit to drill out the part still in the head. This way it may screw out when drilling it for the easy out.
IIRC each easy out uses a certain size drill bit to work right.
You may wind up drilling it out larger and using a Helicoil to fix the threads.
https://www.google.com/?gws_rd=ssl#q=helicoil
Dave ----
hest_c
Apr 21, 2016 12:11 PM
scottlathrop
Mar 10, 2016 05:23 PM
1950F2
Oct 22, 2013 12:48 PM
Fordfreak1978
May 14, 2012 10:04 AM
nevrenufhp
N. California Chapter
May 9, 2010 10:51 AM
