Same issue new question
Old Oct 17, 2016 | 09:59 PM
  #31
robs97z28's Avatar
robs97z28
Thermostat will not cause that at all! Drive on freeway first. if no change replace sensor.
Old Oct 17, 2016 | 10:53 PM
  #32
VictorwithaC's Avatar
VictorwithaC
I get normal temps on the free way and cold soak is within 1 degree of eachother if not spot on. I guess maybe replace the sensor would be logical the eot will go from 183 to 194 city driving usually 186 to 188. With ect being 190 to 194 usually.
Old Oct 17, 2016 | 11:11 PM
  #33
Mcrafty1's Avatar
Mcrafty1
You have something else going on....water cools the oil, once up to temp the oil temp will ALWAYS be a little above the water temp, without the water to cool it the oil would boil, I would suspect sensors.
.....or at least something on the electrical side
Old Oct 18, 2016 | 05:37 AM
  #34
VictorwithaC
Yea I thought sensor at first but since the cold soak numbers were good...I'll just get one and see what happens
Old Oct 18, 2016 | 05:31 PM
  #35
VictorwithaC
You guys know best place to get one? I've seen them for $30? Anywhere cheaper? Also eot and ect sensors the same?
Old Oct 18, 2016 | 09:38 PM
  #36
robs97z28's Avatar
robs97z28
from what I have read they are the same.
Engine Oil/Coolant/Fuel Temperature (EOT/ECT/FT) Sensor AP63437
OEM Part Numbers: 3C3Z10884AA, SW6052
Year Range: Application:
2003-2007 F Series, Excursion
2004-2010 E Series
2006-2010 4.5L LCF
Coolant Temp Sensor | Genuine Ford | 3C3Z-10884-AA
Old Oct 18, 2016 | 09:56 PM
  #37
VictorwithaC
2004-2010 E Series
2006-2010 4.5L LCF
Coolant Temp Sensor Genuine Ford 3C3Z-10884-AA
That SW6052 is the same thing? I saw the one at tousley but amazon has the SW6052 for 22 and it's prime, Motorcraft part.
Old Oct 18, 2016 | 10:11 PM
  #38
robs97z28's Avatar
robs97z28
yes, it is but it is a coolant fan switch. funny, I didnt catch that before. According to Alliant power, they are the same.
Old Oct 18, 2016 | 10:20 PM
  #39
VictorwithaC
yes, it is an Alliant power part number. i would use prime.
Cool deal thanks man!
Old Oct 18, 2016 | 11:02 PM
  #40
04badford's Avatar
04badford
Wholly Bjeses Victor what an ordeal , did you finally get a OEM thermostat ? When the engine was overheating did the fan ever engage , here's some good luck for ya
Old Oct 19, 2016 | 06:13 AM
  #41
VictorwithaC
The thermostat in her is new yea I replaced it after my flush but before my new cooler. Let me tell you what a problem child it was when I first got her. I'm new to diesels as this is my first. I knew a bit of what to look for but obviously not enough. Bought the truck did all the filters and fluids. Then degas got a hole in it, broke the secondary fuel while doing blue spring upgrade, oil cooler and egr delete, new radiator, and then the issue we speak of now. It was quite the Rollercoaster but I think I have the kinks worked out. The wife was not happy cause all that was in the first like 1500 miles of ownership. Anyhow she is a beast now and luckily I can do the work myself so it wasn't too hard on the wallet. Thanks for the luck I'll take all I can get!
One Sock
Jan 9, 2019 09:39 PM
saauvenshine
16
Feb 1, 2015 11:47 PM
JoeSwing78
Aug 31, 2009 11:14 PM
86Stepside
24
Apr 5, 2009 02:35 AM
kevinstang2
Dec 4, 2002 09:37 PM
