Beef up front suspension?-cheap
Old Jan 6, 2002 | 09:46 PM
Norten's Avatar
Norten
I just had my plow switched over from an '87 F-150 to an '89 full size Bronco. The front end of the Bronco sags with the plow raised. I plan to use the Bronco ONLY to plow my own driveway- it will NOT be on the road. Does anyone have a suggestion to beef up the front end- quick and cheap. I put a few rubber plugs in the coils and that helped some. I've thought about getting air bags for the coils but that is about $200 more than i wanted to spend. I don't care how stiff the ride is, as long as it won't damage the truck. Any ideas would be appreciated.
Thanks in advance.
Norten
Old Jan 6, 2002 | 10:37 PM
cpnhgnjnky's Avatar
cpnhgnjnky
Try putting in an ADD-A-LEAF kit, they are cheap quick fixes for just your such dilema. It will drive and ride stiffer though. Wait my bad an 89 TTB, well new springs then.
CJ
Old Jan 7, 2002 | 04:57 PM
Norten's Avatar
Norten
Someone at work told me I should just strap a 2 x 4 to the frame where the rubber things (whatever you call those rubber blocks that hit the frame when the coil bottoms out) and the frame meet. Will this work?
Norten
Old Jan 7, 2002 | 08:27 PM
brett_d's Avatar
brett_d
Man you must of talked with a Che%$ mechanic. Don't put a 2x4 in under the rubber mount. The mount is for when the rig bottoms out to keep your suspension from damaging anything. A 2x4 will cause it to bottom out more quickly and will cause major handling problems. Not to mention your Ford will start to look like a Che%$ with jimmy rigged fixes like that.
You can get taller/beefier coil springs which will fix your problem....
Old Jan 7, 2002 | 08:36 PM
Norten's Avatar
Norten
Thanks for the input- that sounds good. I still have the retired
F-150. Any chance the coils from that could be used in the Bronco?
Norten
Old Jan 7, 2002 | 11:43 PM
mike460's Avatar
mike460
radium
6.7L Power Stroke Diesel
18
May 14, 2016 06:47 AM
raidscsi
Oct 21, 2011 09:18 AM
Firstonraceday93
20
Jan 29, 2011 09:17 AM
GLR
1978 - 1996 Big Bronco
Nov 5, 2007 10:26 PM
WINDFIELD
1997 - 2003 F150
15
Jan 4, 2003 10:39 AM
