Transmission whine
Old Sep 12, 2016 | 11:28 AM
sam hain's Avatar
sam hain
Transmission whine
2004 supercrew 2wd, 5.4 - 3.73LS with 132k on it, just bought it 2wks ago and lately noticed a whining sound between approx. 20mph and 55mph, noise goes away when TC locks. I thought it was tire out of balance or low psi but that doesn't seem to be the problem. The noise isn't present when the truck is running in park, only at speed. I did some research this morning and keep coming back to the #9 Torrington bearing (output shaft) and thousands of dollars to repair. I'm praying that's not the issue with my truck.
Old Sep 12, 2016 | 06:20 PM
Marvan's Avatar
Marvan
Bearing
I had a problem that sounded similar. It was the pinion bearing. Good Luck!
Old Sep 12, 2016 | 10:10 PM
jk080's Avatar
jk080
Transmission Rebuilder
If the noise goes away when the converter locks up I would suspect a bearing or something in the converter. If the only condition is the noise and there is minimal debris in the pan you may get away with just replacing the converter.
Old Sep 13, 2016 | 06:26 AM
sam hain's Avatar
sam hain
I'm leaning towards a pinion bearing myself, my FIL and I looked at the truck last night and the whine is coming from the bed area of the truck not underneath the dash/cab area. We also noticed the passenger side rear wheel seal is leaking and after a 25min drive the differential is very hot to the touch. When the axle is put in a bind like turning in a parking lot at slow speeds the axle also makes a popping sound. This truck has a LS slip rear end so I'm also wondering if something with that has messed up? I'm no mechanic so I'm just covering my bases.
Old Sep 13, 2016 | 09:06 AM
jr105's Avatar
jr105
Have you checked the level of the oil in the rear end? If this was mine I would drain and refill the gear oil in the differential using a friction modifier before anything else. If that didn't help I'd get into the more expensive stuff and replace the axle seal either way.
Old Sep 13, 2016 | 09:40 AM
sam hain's Avatar
sam hain
Yes I checked the fluid level and it was correct. We found a local axle guy that was highly recommended so I'm going to let him drive the truck and see what he thinks the problem might be. With the diff fluid getting that hot, the whine, the popping/clunking and the axle seal leaking I don't think replacing the fluid is going to do much.
Old Sep 15, 2016 | 07:23 AM
sam hain's Avatar
sam hain
Passenger side rear wheel bearing and seal needed replaced. Noise is gone now.
Old Sep 19, 2016 | 10:30 AM
sam hain's Avatar
sam hain
Welp, "some" of the noise is gone but the high pitched whine is still there and IMO seems to be coming from the torque converter.
*not my truck* but this is the sound.
wrxin
Jul 9, 2014 06:31 PM
Mikeyman07
1997 - 2003 F150
Jul 2, 2014 08:15 PM
mprice
Apr 7, 2008 09:18 PM
blyons33
1997 - 2003 F150
Dec 5, 2007 10:52 PM
Rancha9
Jun 26, 2006 09:56 PM
