Sputtering issues 1991 Ranger XLT
Old Aug 21, 2003 | 05:13 AM
Talon Warlok's Avatar
Talon Warlok
Question Sputtering issues 1991 Ranger XLT
I must say that you all are very helpful from what I've read on these boards - which is why I just joined.
Over the last two weeks my 91 ranger (2.3L 4cyl) has been periodically sputtering, there does not appear to be any routine to it. I've been pushing in the clutch pedal when it starts to sputter and that seems to fix it for a while. I assumed it was the fuel filter so I replaced it and I thought that worked, until it did it again two days ago.
I bought a replacement fuel pump but then realized the hassle of putting it in and before I go through all that I want to make sure there isn't an easier fix.
I've been told it could be anything from air intake to the cat converter and even a chip.
Any suggestions ?
Old Aug 21, 2003 | 03:26 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I would start by checking for codes (see tech info post) and testing fuel pressure.
Old Aug 21, 2003 | 03:35 PM
FoxRider934's Avatar
FoxRider934
Yeah i would check out the air filter, try putting some carb cleaner in it, and go from there i have a 91 too, and i had the same problem, i had to rebuild my carb, does yours sputter after a certain RPM?
Old Aug 23, 2003 | 06:24 AM
Talon Warlok
I am having it diagnosed today to see what comes up.
I haven't noticed it doing it at any specific RPM or when revved too high, it's weird I tell ya' totally random. The check engine light did blink though. I had it up to 95 yesterday without so much as a glitch yet last night just cruising on home it did it again. I'm just afraid that the machine won't come back with anything or that the mechanic will tell me it's some $400 part.
It seems to be fine when I push in the clutch (stabalizes the idle) I am wondering if it's worth it to fix or is this going to get worse?
Old Aug 23, 2003 | 10:49 AM
FoxRider934
Well if you have some internal problem, and you keep driving on it, yes it will get worse, I would just take it to somewhere
Old Aug 24, 2003 | 06:48 AM
Talon Warlok
Post Sputtering issues 1991 Ranger XLT
I took it in to Firestone and had it checked out - they were pretty clueless. The diagnosis came back with an EVP Sensor out of range and something about the EGR Valve.
They reccommended changing out the Sensor (P&L = $130), I can afFORD it but I'm not sure it will fix the problem.
Any suggestions ?
Old Aug 24, 2003 | 09:19 AM
GrayRanger4x4's Avatar
GrayRanger4x4
If that the codes that showed up,its a good bet thats the problem,or at least a good place to start . Look for bad conections or bad wires.Sometimes a wire or a conection could be bad or lose and could cause a intermittent problems.JM.02W
Old Aug 24, 2003 | 05:06 PM
FoxRider934
I would also vacuum test the EGR, to see if it will hold the vacuum.
FoxFord33
Feb 1, 2017 05:53 PM
johnson.jeff.a
16
Nov 26, 2014 06:58 PM
bly8397
Mar 14, 2014 04:11 PM
03XL
1997 - 2003 F150
Mar 4, 2014 11:17 PM
randy1973
Oct 25, 2011 10:05 PM
