Brake peddle bleeding
Old Sep 11, 2016 | 01:15 PM
timmyboy76's Avatar
timmyboy76
Noticed while hooking up fog light, that the cylinder the that protrudes through the firewall for the brake, is wet with tran fluid. Hadn't dug into it, but anyone offhand know what I'll be getting into/replacing...
Old Sep 11, 2016 | 09:58 PM
Bonanza35's Avatar
Bonanza35
My hydra boost was leaking so I replaced it. It wasn't bad but I keep seeing ATF on the ground. It was hard to trace.
Old Sep 11, 2016 | 10:16 PM
timmyboy76's Avatar
timmyboy76
Thanks Chet... Looked into rockauto and it looks like a "unit" of some shirt that needs replacing. Nothings showing up on the ground nor wet in the cab, but not digging what I found
Old Sep 12, 2016 | 02:16 PM
Bonanza35's Avatar
Bonanza35
There was a weep hole on the hydra boost on mine and it dripped in the wire harness for a while then down where you wouldn't expect to see it. Was hard to find. Mine never leaked inside either. Just saying what I found on mine. I had know other problems with it either.
Old Sep 13, 2016 | 10:44 AM
spongecop's Avatar
spongecop
Semper Fi
i replaced mine with a Cardone reman...half the price and working well so far.
Shovelheadrob
Nov 30, 2018 07:34 AM
Savage19NRA
Mar 8, 2018 01:07 PM
nc150
Nov 10, 2005 12:39 AM
Finally
Sep 4, 2004 09:39 PM
Fritolay
Jan 24, 2004 02:32 PM
