Circuit Board Medics
Old Sep 11, 2016 | 02:29 AM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
I was having various issues with my truck the last three weeks. I had intermittent power windows and instrument gauges, interior dome lights had a mind of their own, ESOF would not work, 3 different DTC's ( one unknown, PCM lost communication with instrument cluster, TCM lost communication with PCM), truck felt like it was starting in second gear and would not shift into OD, and engine would have a periodic miss. I pulled the instrument cluster and sent it off to Circuit Board Medics and had them work it over, upgrade it to LED lighting, and install a new lens. WOW! After I re-install the cluster all those problems were solved! I shipped it off Tuesday (UPS next day air and they had it on it's way back Thursday via FedEx next day service. I had it Friday at 4 pm and installed it this morning. Fantastic service from that company is what I want to tell you! If you are having similar problems then talk to these guys. I highly recommend them.
Old May 31, 2017 | 09:25 PM
coolfeet's Avatar
coolfeet
I am sending my 2004 E350 PSD 6.0 Instrument Cluster to Circuit Board Medics for repair. I am a little nervous about the disclaimer that the repair may not work.
I prefer a rebuild service. I see that Circuit Board Medics offers this for the F series.
The reputation Circuit Board Medics has on the forum is stellar.
Old May 31, 2017 | 10:16 PM
FiznUKa's Avatar
FiznUKa
When I purchased my truck I sent them my FICM to be checked out. They called when they had it on the bench and said there was nothing wrong with it but I told them to repair the known problem areas they did and sent it back to me. Still going strong and would use them again. Hope you have the same experience I did
Old May 31, 2017 | 10:50 PM
coolfeet's Avatar
coolfeet
thanks. I packaged the instrument and will send it off tomorrow.
Old Jun 1, 2017 | 05:59 PM
87crewdually's Avatar
87crewdually
I've sent them Volvo XC90 cluster that was going crazy and they repaired it and is still going strong.
The chat tech online was helpful and quick turn around on the shipping. That's been my experience.
Old Jun 2, 2017 | 10:20 AM
coolfeet's Avatar
coolfeet
I sent the instrument cluster in yesterday to Circuit Board Medics and paid the extra $30 for the LED light upgrade.
Old Jun 3, 2017 | 12:45 AM
04badford's Avatar
04badford
Following with a big bag of buttered popcorn
Old Jun 3, 2017 | 10:02 PM
87crewdually
Old Jun 3, 2017 | 11:25 PM
04badford's Avatar
04badford
Originally Posted by 87crewdually
Nothing bad , just following. In another FTE section the sweat solder was causing instrument panel black out , curious to see if this is the same culprit.
Old Jun 4, 2017 | 07:00 AM
87crewdually
Actually on the top left corner if the board on my truck I found a bad joint but I reflowed it myself. That was years ago and can barely remember the joint or the symptoms it was causing.
Old Aug 26, 2018 | 03:36 PM
ascrap2003's Avatar
ascrap2003
i know its a old thread but I figure helpful,
I used DFW cluster repair to fix my cluster they fix F150-F350 Clusters and Mustang. I had them do a few of mine, my whole family from grandfather to son drive ford.
Link if you need em, great reviews too!
DFWclusterrepair
Old Aug 26, 2018 | 08:40 PM
coolfeet's Avatar
coolfeet
My repaired instrument cluster works great with the new LED lights. However, I just noticed the speed is off my 5 MPH. At idle, it reads 5 mph.
It's too late to send it back for repair and not worth the shipping charge. I figure I need to let Circuit Board Medics know that this should be checked prior to sending the units back.
I would use Circuit Board Medics again. Customer service is great. Turn around time is fast.
Old Aug 27, 2018 | 01:20 AM
Yahiko's Avatar
Yahiko
I have talked to them on the phone about some things and they were very good at helping. I would like to someday have then do the side gauges in the white background but because
my is an Amarillo and they have not had enough call for the white gauges on the side they have not had any face panels printed up that also have the Amarillo logo. I am thinking about
the LED option if I do need a cluster worked on.
Old Aug 27, 2018 | 03:12 PM
njfirefighter15's Avatar
njfirefighter15
I had the exact same symptoms as the OP in an 06 Amarillo and sent mine in to Circuit Board Medics, ordered the LED upgrade and replacement lens. I can also confirm a super-fast turnaround time, and their repair has solved all of my issues - another happy customer!
Old Aug 27, 2018 | 03:46 PM
Yahiko's Avatar
Yahiko
Would you do me a favor and post a night photo of how the cluster looks with the LEDS on in the dark?
