Trying to remove steering stabilizer
Old Sep 9, 2016 | 10:20 PM
Amicus's Avatar
Amicus
Gentlemen
Trying to replace my steering stabilizer and in the process I broke the nut close to the steering box. Would not budge so used a bar and well I broke it. Now I can't pop it out am I doing something wrong? Here are a few pics. I'm totally bummed nothing seems to be working for me. Any help would be greatly appreciated.
Old Sep 9, 2016 | 10:25 PM
87crewdually's Avatar
87crewdually
SEE PIC
Smack it with a hammer on the circle while pushing UP at the arrow.
Old Sep 9, 2016 | 10:31 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
You can also warm up the drag link with a torch then smack it with hammer. That will help for sure.
Use a punch
Old Sep 9, 2016 | 10:37 PM
Amicus's Avatar
Amicus
Thanks 87 will give it a shot in the morning. The way I feel I'm bound to break something else. Earlier i was installing some kicker speakers that I ordered from Cruthfield . I've been anxiously waiting for them when got home they were waiting for me. Took my time installing making sure the wires were hidden running thru the door and under the dash. Any way one of the speakers does not work right so will have to wait till tomorrow to call and complain.
Thanks for the help
Old Sep 9, 2016 | 10:49 PM
87crewdually
Some speakers are polarity sensitive. Try flipping the wires on the one not working.
Old Sep 9, 2016 | 10:59 PM
Fuzzpuss's Avatar
Fuzzpuss
A two armed gear puller might work, but you'll have push the arms together with a clamp to keep them from slipping off the drag link.
You could also try a ball joint pickle fork. About $15 at the parts store.
Could be that just letting it sit overnight with PB Blaster will help a ton too.
Old Sep 9, 2016 | 11:09 PM
Amicus's Avatar
Amicus
Thanks guys I really appreciate the help. Started to pull out the torch but decided to wait til morn.
Old Sep 9, 2016 | 11:11 PM
87crewdually
Save the heat for last resort.
Old Sep 9, 2016 | 11:41 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
X2. It's just a taper, hit the broken end of the bolt with a big pin punch and it'll pop out.
Old Sep 9, 2016 | 11:55 PM
twigsV10's Avatar
twigsV10
Try this ^^^^^^.
The last two stabilizer's i've replaced only required a solid whack on the end of the stud with a hammer to unseat them, using a punch at this point would be the same.
Old Sep 10, 2016 | 06:54 AM
Jerky's_06 F350's Avatar
Jerky's_06 F350
This is what I had to use. Popped right out.
Tried to get a few good solid wacks on the stud but there wasn't enough room to get a good swing started.
Old Sep 10, 2016 | 12:57 PM
Amicus's Avatar
Amicus
Thanks everyone been banging on it all morning and won't pop out. Tried the air hammer and that didn't work. If I heat it with a touch what part do I heat?? I don't want to damage the ball joint connected to steering box. I have the fork tool but the forks are not thick enough. Going to get a puller and see if that will work. BTW, Cruthfield service is awesome they are sending me another pair of speakers. Will keep u posted
Old Sep 10, 2016 | 01:12 PM
TooManyToys.'s Avatar
TooManyToys.
Be never had a problem popping a tapered shaft doing what 87crewdually showed you to do. I just did this a few days ago on the tie rod end for the pitman arm. What size hammer are you using?
Old Sep 10, 2016 | 02:20 PM
mhatlen's Avatar
mhatlen
Heat up the drag link around the bolt itself. Keep heat away from bolt. You want to expand metal around the bolt so it gets bigger and will pop out easier.
Old Sep 10, 2016 | 02:53 PM
Amicus's Avatar
Amicus
Still can't get it out. Went and bought a pully and still can't get to work. I guess I use some heat and see what happens. I do have a good hammer and pin but it won't budge.
