Air cleaner warm air
What is the best way to add warm air to my factory air cleaner when I put EFI exhaust manifolds on? Weld a piece of exhaust pipe to the side of the Y-pipe to put the hose on? Do they still make the clamp on style for headers? I have the hot water plate for the intake, but that doesn't help much when it's cold. Thanks!
But you could do some searching in a older salvage yard, find something and then modify it to work. It doesn't have to be from a V6.
Or it might just be easier to take some card board or tag board. Make some patterns. Transfer it to metal. Cut it out, make some bends, drill some holes then weld or rivot a piece of pipe/tube to it. Mount it up and be good to go.
FrankGRUN
Air Intakes, Air Filters & Ram Air
09-13-2010 03:02 AM
flyerskid716
13
05-11-2009 05:11 PM
sum_weirdo
20
07-05-2007 02:31 PM
Nut
03-10-2006 11:09 AM
MRStace84
04-02-2005 09:32 PM
