Sponsored by: Real Truck
Leak?
Old Sep 7, 2016 | 10:38 PM
MEGATRON2010's Avatar
MEGATRON2010
Leak?
Bare with me. I'm by no means no mechanic and not experienced in parts or mechanic work. So I just got my truck a few days ago. 2010 F250 6.4. I was changing a fog lamp bulb when I noticed a drop of fluid fall on me. Didn't think anything of it, but then I noticed a hose that seemed to be moist. I wiped it off with a rag. Few minutes later, it's wet again with a puddle the size of a nickel. It doesn't smell like anything. Not noticing any color, although it's dark and with my flashlight it's hard to tell if there's a green tint (coolant?) or not. Here are a couple of pics that I tried to get. It's on the drivers side close to the fog lamp area. Any idea what it might be? Thanks with any help in advance.
Old Sep 7, 2016 | 10:44 PM
m-chan68's Avatar
m-chan68
Appears to be yet another 6.4L diesel with rad leak. Very common.
Old Sep 7, 2016 | 11:01 PM
MEGATRON2010
Radiator leak? Dang...now to find a solid mechanic. So assuming hose needs to be changed?
Old Sep 8, 2016 | 01:15 AM
Ultimate Automotive Leak Detector's Avatar
Former Vendor
You do know you might just need to tighten a hose in some cases.
Old Sep 8, 2016 | 01:22 AM
Former Vendor
Leak detector
Can locate hose leaks intake manifold leaks exhaust leaks and a host more of leaks and it only takes moments to locate them.
Old Sep 8, 2016 | 04:45 AM
EDC8008's Avatar
EDC8008
My 2010 had the same thing happen 2 days after I bought it (45000 miles). Had developed a radiator leak that was caused by the upper hose was the issue. There was a service bulletin on it so got it repaired for free by Ford.
Old Sep 8, 2016 | 10:30 AM
MEGATRON2010
Thanks for the replies. Have appointment with reputable mechanic, hopefully it's just a hose.
Old Sep 8, 2016 | 03:47 PM
MEGATRON2010
Confirmed, it's the radiator! Pressurerized it and showed me that the number of drops increased right on the corner of the radiator. $1250 with new radiator, hoses, and labor. It blows..but dang, I love my truck. Now to save my pennies!
Old Sep 8, 2016 | 09:26 PM
m-chan68's Avatar
m-chan68
I'll assume you will be replacing both the upper and lower rad hoses with the updated white plastic necks from Ford as well, to go along with your radiator. A set of thermostats wouldn't hurt either while you're in there as well since they fail pretty commonly too.
Old Sep 8, 2016 | 11:14 PM
MEGATRON2010
Yes, new hoses. I'll throw in the thermostats as well. Thanks for the tip.
Patriotgrunt
Aug 14, 2016 08:27 PM
acstator
6.4L Power Stroke Diesel
Feb 6, 2015 02:12 PM
wrd0225
Jun 29, 2013 09:29 PM
PSDx3
Jun 28, 2013 09:57 AM
larro823
Oct 4, 2005 08:01 AM
