Carb size?
Old Sep 6, 2016 | 03:15 PM
jrockdiddy's Avatar
jrockdiddy
Carb size?
Hey guys,
When I smash the gas on gear, the motor feels like it wants to die. In neutral it revs a lot better, under load not so much. It's a 351w, .030 over, I'll have to get the cam specs, but pro comp aluminum heads, weiand intake manifold, edelbrock 750cfm. My plugs were black so I went up in jet size just one size. Haven't checked plugs. I took the air cleaner off, and the motor runs 10x better. But still under WOT, not 100%. Is there anything that jumps out that could be an issue??
Fuel filter is clean, manual fuel pump. 6psi. Maybe timing? Accelerator pump on carb?
Old Sep 6, 2016 | 05:25 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Black plugs are rich so going up is backwards. If you have no pinging go more advanced on timing and go the other way with jetting. See what happens
Report back
Old Sep 6, 2016 | 05:44 PM
jrockdiddy's Avatar
jrockdiddy
Gotcha. Let me pull a couple spark plugs and I'll report back. That makes more sense.
Old Sep 6, 2016 | 07:23 PM
hooler1's Avatar
hooler1
Originally Posted by jrockdiddy
Hey guys,
Since you pulled the air cleaner and the engine runs better your engine is telling you it wants a leaner mixture. A 750 cfm carb might be too big for a 351. A 600 cfm carb would be about right if not still be a little on the large size. But I am betting your engine is going to like the 600 better. Did you check you carbs float level, then set the idle mixture volume screws? I don't know a lot about Edelbrocks, but if this was a Holley the next things I would look very closely at is maybe a leaking power valve or accelerator pump. No matter which carb you use, start with the stock settings the carb came from the factory with, then tune from there
This is especially important if you bought the carb 2nd hand.
Old Sep 6, 2016 | 11:04 PM
jrockdiddy's Avatar
jrockdiddy
I thought the idle mixture screw only affected the engine at idle? I'm gonna adjust the accelerator pump setting first, then see what happens...
QUOTE=hooler1;16553933]Since you pulled the air cleaner and the engine runs better your engine is telling you it wants a leaner mixture. A 750 cfm carb might be too big for a 351. A 600 cfm carb would be about right if not still be a little on the large size. But I am betting your engine is going to like the 600 better. Did you check you carbs float level, then set the idle mixture volume screws? I don't know a lot about Edelbrocks, but if this was a Holley the next things I would look very closely at is maybe a leaking power valve or accelerator pump. No matter which carb you use, start with the stock settings the carb came from the factory with, then tune from there
This is especially important if you bought the carb 2nd hand.[/QUOTE]
Old Sep 6, 2016 | 11:35 PM
EBEAR's Avatar
EBEAR
Definitly too rich that's a lot of carb , you should be able to make it work jet down , set the accelerator pump down , set your timing up and probably most important with an edelbrock you can set when the secondarys open so you want to set them to come on much later when the engine is reving and needs more fuel
Old Sep 6, 2016 | 11:47 PM
jrockdiddy's Avatar
jrockdiddy
I pulled the number one plug tonight..
Old Sep 6, 2016 | 11:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Edelbrocks use metering rods, no power valves. They sell a tuning kit that includes charts showing how metering rod changes affect Air/Fuel ratio, and include an assortment of jets and rods.
Old Sep 7, 2016 | 12:11 AM
jrockdiddy's Avatar
jrockdiddy
Anyone use one of these air/fuel gauge kits???
AEM Wideband UEGO Gauge - Digital Air/Fuel - 30-4110NS w/ Bosch 4.9 Sensor - Enjuku Racing Parts, LLC
sparky's Avatar
sparky
Believe it or not a 500cfm would probably be enough carb..... but a 600 would be fine. You can jet down the 750 carb, probably cheaper than getting a replacement carb.
You are definitely getting too much fuel, hence the running better with no air cleaner... as there is less air restriction..... and the black plugs.... way too much fuel.
Old Sep 7, 2016 | 03:11 AM
truckeemtnfords
You are a little rich based on that plug. You can always go smaller jets but the other thing on those carbs is the metering rod springs. With any kind of cam you usually need a lighter spring to delay going rich when the spring and low vacuum pushes the m. rod up.
Old Sep 7, 2016 | 08:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, I have an Innovate system installed on my flathead. It's the only way to get real data. Plugs are very hard to read with gasohol.
Old Sep 9, 2016 | 01:06 PM
petemcl's Avatar
petemcl
Yes, way too big a carb and IMHO jets won't really help that much. See Holley's carb size calculator:
https://www.holley.com/products/fuel...s/carburetors/
That digital AFR meter is really trick though.
Old Sep 9, 2016 | 03:33 PM
truckeemtnfords
I don't agree that the carb is to large. It just needs to be tuned to the combo he has. Using the link provided they recommend either a 670 or 750 cfm carb. No 600 and definitely not a 500. Like everything, when it is modified, items out of the box need tweaking. That carb is based on the old Carter AFB, which is a great carb. It has mechanical linkage secondaries and engine vacuum activated butterfly for air flow through the secondaries. It will only pull what it can use, that is one of the reasons why it is great carb. Spend the time learning how to adjust it correctly and you will not be disappointed. I run them on several engines and installed lots of them at the speed shop. Never an issue when adjusted correctly. You can always pm me for tips and tricks on tuning.
Old Sep 9, 2016 | 04:05 PM
petemcl's Avatar
petemcl
Hmmm . . . well maybe we are looking at a different page. Here is what I entered:
Carb sizes are 570-650 cfm with 22 choices.
Per the Holley book over-carburetion is the most common error made. It robs bottom end torque and raises the RPM where max HP & Torque occur. If this is out of the normal driving range your drive-ability will suffer. It is a common error made by off-roaders where bottom end torque is a necessity for control particularly in severe off-road conditions at altitude like the Rubicon Trail.
