After some investigating, i have found that the tone ring on the passenger side is split which is causing the ABS to kick on at low speed every now and then.
I have replaced a tone ring on an escape, i am just wondering if its a similar job to do on the econoline. after looking on rock auto, im not seeing just the tone ring. maybe i have to replace the whole hub?
wow im surprised! maybe i call ford and see if just the ring is available or if i have to buy the whole hub.
If you wouldnt mind taking a photo of how the ring is mounted, that would be great!. theres not much online and i dont want to pull my van apart just to see.
its a 2010 e250 with a 4.6
Mine is a 07 E350 with V10. I think there was a factory brake redesign/upgrade in 2008, therefore I suspect our brakes are not interchangeable.
So i did some digging. yes, the tone ring comes on the rotor/hub when you buy the assembly. The ring alone is $79 CDN i think ill just wait and but the whole assembly when my rotors are dead..
