flooring alternative/noise reduction
Old Sep 5, 2016 | 03:04 PM
champipple's Avatar
champipple
on a stroll thru loews the other day i found flooring made from recycled tires, typically used in utility areas like a weight room floor, it it pieces together like a puzzle and fairly easy to work with. I trimmed away the excess w/offset tin shears[had an extra pair]. it didn't cover the entire cab area but reaches mid way under the seat to where it shown in this pic.
was much less expensive than some other products so i went for it. ill toss the carpet over the top and I'm good to go. original cost, $30 for 12, 12" pieces w/finishing edges and corners. this was an open box for $15,I've paid more for bad meals and felt i couldn't pass it up.
lata
Old Sep 6, 2016 | 11:46 AM
BAD ROD's Avatar
BAD ROD
How does it work for noise reduction?
Old Sep 6, 2016 | 06:19 PM
Walston's Avatar
Walston
Seems like a good idea. Did it help with noise?
Old Sep 9, 2016 | 01:54 PM
champipple's Avatar
champipple
the noise reduction component isn't complete yet, i plan on using fat mat on the roof as well as inside the doors and adding a headliner. Currently any and all noise resonates in the cab area and wanting to cut down on that.
ktgovols
Jun 17, 2016 04:19 PM
vfelix702
Jan 22, 2015 11:28 PM
Hitokori
25
Feb 17, 2011 09:20 AM
RangerRuss
Mar 23, 2006 06:38 PM
