Blown Head Gasket???
Old Sep 5, 2016 | 10:30 AM
acameron1934's Avatar
acameron1934
So I finally finished the steering issue, front crank seal, new plugs, new cap, new tires, and new valve cover gaskets on my truck and I'm still getting white smoke out of the passenger side of the engine best I can determine it comes right out from behind the exhaust manifold. It is also coming out of the passenger side tail pipe but not the driver side. I'm worried this might be blown head gasket or worse. I haven't replaced head gaskets on anything before but plan to do this one myself anyways. neither ALLDATA nor my Haynes manual give me any info on the required steps to do this. Help please haha I need this truck running smooth in a few weeks.
86 F150 Reg Cab/ Long Bed
Carb 302 and 4 speed manual
I know the 86 didn't come carbureted but this is how I bought it.
Old Sep 5, 2016 | 08:55 PM
Franklin2's Avatar
Franklin2
You need evidence. Pull the sparkplugs on that side, are any of them fouled with gooey green stuff? Are you losing coolant? You may need to drive it a little bit so the evidence is easier to see, as in the stuff to build up on the plugs, and keep checking the coolant level.
Old Sep 6, 2016 | 10:41 AM
acameron1934
I had just put new plugs in so i guess im just gonna have to wait and see drover it to work this morning didnt see any smoke coming out the pipes on the drive. My father in law thinks it could have just been condensation from sitting the past few weeks in the cold
Old Sep 6, 2016 | 05:57 PM
FuzzFace2's Avatar
FuzzFace2
Yep that is what I would say it is. Now you said it came out the manifold? Is there a exh leak at that point?
If you have a 50/50 mix in the radiator and it is a bad gasket, could it be intake gasket bad? When coolant is pushed out the exh it has a sweet smell to it and kind of hangs around a little longer.
I would drive it more and keep eye on coolant level.
Dave ----
Old Sep 8, 2016 | 10:16 AM
Plowboy34's Avatar
Plowboy34
is the coolant level going down as you drive it? Also you say smoke is coming out from behind the manifold, exactly where do you mean. Is it like from the back of the head(the part towards the firewall), if that's where you mean the thermactor plug could be getting rusted out a little and you have an exhaust leak there. If this is true then I would not believe it is condensation as it would not be built up in the engine that bad. Also as said if you have antifreeze in engine the steam should have a sweet smell to it.
Old Sep 13, 2016 | 02:45 PM
acameron1934
update* not losing coolant, coolant color looks normal, very minor smoke from between exh man and engine guessing its just a bad gasket. no abnormal smell.
Toreador_Diesel
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 8, 2016 12:14 PM
John McCabe
1983 - 2012 Ranger & B-Series
Nov 17, 2014 02:43 AM
Dale Cooper
Jun 6, 2014 11:16 AM
jonblaze77
1997 - 2003 F150
Jun 8, 2006 09:43 PM
GoldenDually
Dec 20, 2003 06:55 PM
