Sponsored by: Auxito
Head Gasket??
Old Jun 6, 2006 | 04:22 PM
jonblaze77's Avatar
jonblaze77
Head Gasket??
Hello fellow Ford Enthusiasts, I own a Canadian 1997 F-150 (4.2, V6,)with 220000kms. I went to start my truck and there was quite a loud thud. After 15 sec she was running fine but noticed white smoke billowing out of the tail pipe, under the hood the coolant looked good. My neighbor heard the thud and came out side, seen the white smoke and told me to shut her down thinking it was a head gasket leak. The next couple of days it was left until I could make a appointment at the local shop which is around the corner, went to start it up and there was quite an uncomfortable knock in the head. My question is, has anyone heard of this type of truck having these problems and what to do? I've called a couple dealer ships service depart. and some say it could be the head gasket seal failure and the cylender is damaged, or they've never heard of any problems with this type of motor. I have some knowledge of vehicle's from owning my own, but I'm no mechanic and I'm a little worried I might be mis lead when I bring it in. Please Help, Thanks.....
Old Jun 6, 2006 | 06:17 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Angry
Your lower intake gaskets,not head gaskets,have failed and allowed coolant into one or more cylinders.Upon start up,a piston cannot compress a liquid,so your engine "hydro-locked" and bent and/or broke a rod.Go to the "4.2 Forum" and do a search on "hydro-lock".
BTW,the Ford dealerships know all too well about this problem! They are basically blowing smoke up your "donkey"!
Old Jun 6, 2006 | 06:52 PM
jonblaze77's Avatar
jonblaze77
Looks like a rebuild...Thanks for the info Blue...
Old Jun 8, 2006 | 08:10 PM
gti1599's Avatar
gti1599
try pulling the plugs, then cranking the motor. This will get the coolant out of the cylinders. Then try starting it again. If it starts and doesn't run normal, you probably broke something. If it runs o.k., replace the intake manifold gasket a.s.a.p. The same thing happened to me. I just finished replacing the gasket yesterday. Hopefully, all is well. The total on parts for D.I.Y. was like $100. Make sure you get a torque wrench in inch pounds, not foot pounds.
Old Jun 8, 2006 | 08:48 PM
BlueOvalFitter
Angry
He said upon starting it up the second time there was a knock.That rite there tells you the damage is done.I have seen several 4.2s go thru this ordeal.I had my lowers replaced by Ford back in 2002 to prevent this and they failed earlier this year,but I got it back to Ford in time to have them replaced,again!
Old Jun 8, 2006 | 09:43 PM
gti1599's Avatar
gti1599
I was just trying to help out. Mine made a terrible knock also. I found this forum and searched. I read that I should pull the plugs. I did this and coolant shot out of the first cylinder on the passenger side. After reinstalling the plugs, and starting her up, it ran hard at first. But, then smoothed out. When I got the intake manifold off, it was obvious where the leak was occurring. The gasket around the area in question was almost gel like. I'm just hoping maybe he'll be as lucky as me. Anyways, my truck is a work truck, I have a VW in the garage as a second car. I feel bad for all that go through this with there daily drivers.
