any 4 link recommendations?
Sep 9, 2016 | 06:53 AM
I did my own setup. If you're handy, you could probably save a few pennies using steel bars etc. Not sure what the after market kits go for?
Sep 11, 2016 | 01:45 PM
Quote:
Originally Posted by
chad77
do you have detailed pics of what you made and how you made it by yourself?
Sep 11, 2016 | 02:08 PM
ingo
If you check out my thread, 56' racecar themed F100, I have lots of pictures.
I used tubes that I bought because I got a really good deal. Easy and much cheaper to use steel and weld in slugs I think. Or even welding nuts to the ends of the tubes would be even cheaper.
I just started welding up everything behind the cab and I hit the welding gun on the ground to get the slag off it and broke it. Fixed it back up and ready to go again.
Here is the frame mount for the parallel 4 link. Just 2x2 tubing. Believe I used 1/8 wall.
Don't hit your welding gun on the ground to clear slag build up..
I had my work make these. Rear end bracket for parallel 4 link. I think you can get them online if you google it or worst case my work..
Nov 19, 2016 | 06:55 AM
chad77
chad, where does your Gas Tank Comes out?
Thank you
ingo
Nov 19, 2016 | 07:06 AM
chad77
chad, where does your Gas Tank comes out?
Thank you
ingo
Nov 19, 2016 | 07:47 AM
ingo
Thank you
ingo
The fill tube you mean? It will be in the driver's side fender.
Nov 19, 2016 | 09:00 AM
chad77
Sorry, i mean whats the donor car?
Nov 19, 2016 | 12:27 PM
ingo
78 Bronco full size tank
Nov 19, 2016 | 06:23 PM
chad77
Thank you,
is there a chance you can give me the dimensions? The total over all and the dimensions of only the balloon?
Nov 20, 2016 | 06:45 PM
ingo
Thank you,
Balloon 29x20. ish
I made a cover for the bottom that is 32½x22
Nov 22, 2016 | 02:01 AM
chad77
Balloon 29x20. ish
good to know, i think i will take that gas tank for my cabover project too, probably the 25 gallon.
thank you much
Ingo
Nov 22, 2016 | 02:21 AM
...ok, thanks again for all your guys recommendations. So for my '56 Truck I decided to go with the No Limit Fat Bar 4 link. I got a Ford 9 inch, the guy i bought it from said it came out of a Lincoln Versailes.
first mock up pic
Nov 22, 2016 | 02:41 PM
Don Vito
Are there any 4 links that are 100% bolt in? No welding necessary.
Don
Don, go back to post #3 in this thread, he said it was bolt on. The only welding is the axle brackets.
Nov 22, 2016 | 03:10 PM
Edit: for some reason my Photobucket isn't posting the correct image file.
I bought the same kit. Mine came with ridetech coilovers. I love it.
http://i658.photobucket.com/albums/uu309/jrockdiddy/Mobile%20Uploads/E4B52D1E-0F08-43AA-AC30-C9E64AA41C80_zpswec5xzkt.jpg
jaclinto
Aug 22, 2012 03:20 PM
keisha9
Jan 1, 2010 04:53 PM
gearheadz80
Alternative Fuels, Hybrids & Mileage
Feb 22, 2007 02:06 AM
truckalpers
2004 - 2008 F150
Jun 6, 2006 03:05 PM
b1gr3d
Apr 4, 2004 10:40 AM
