Removing excess trans fluid
Old Sep 4, 2016 | 07:21 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Was checking the trans fluid in My 1994 F150, and it is about a quart and a half overfull, I checked it after a short 1o min drive in town.
Could I remove the top trans cooler line at the radiator, then start it up and let it pump into a container?
Old Sep 4, 2016 | 07:53 PM
thehead406's Avatar
thehead406
That's what I did. Not going to hurt anything.
Old Sep 4, 2016 | 08:17 PM
mrollings53's Avatar
mrollings53
Sucking it out of the dipstick tube would be the safest bet. Dropping the pan, and refilling would be the next option. Clean the pan, and use a clean catch can so you can reuse the fluid. I personally wouldn't crack a cooler line with the motor running. Nothing like hot hydraulic fluid in your face.
Old Sep 4, 2016 | 08:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
its not that hot to worry about.wont be hot at all if you don't drive it first.
Old Sep 4, 2016 | 09:54 PM
abranz's Avatar
abranz
I use a pella hand pump. Works well for many things
Old Sep 4, 2016 | 10:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
^^ remove the line and stick it or a hose to extend it into a catch pan. Start the truck and let it pump out some of the fluid. That's how I replace the p/s fluid. It won't hurt anything. It's not like your going to pump all the fluid out and run it dry.
Old Sep 5, 2016 | 08:37 AM
Scndsin's Avatar
Scndsin
Un-do the rubber splice line on the return steel line from the cooler (end closest to trans). its not near high pressure at idle & have a measureing cup or something ready with someone on the key to shut down.
That's pretty much why its there.
Old Sep 5, 2016 | 10:27 AM
Lead Head's Avatar
Lead Head
Keep in mind transmission dipsticks don't usually read in "Quarts" like engine dipsticks. Usually the difference between add and full on the stick is 1/2 qt or so.
Old Sep 5, 2016 | 02:05 PM
78 & 87 Super Cab
I got the transmission warmed up to normal operating temp and checked the fluid level. It was approximately 2 and a half inches above full
Old Sep 5, 2016 | 07:58 PM
FORDF250HDXLT
so long as it "was" (for just a few miles) and isn't anymore.
Old Sep 6, 2016 | 10:56 AM
Lead Head's Avatar
Lead Head
You did check it with the engine running, right? Transmissions don't generally gain fluid unless the radiator cooler is leaking.
Also, make sure you check both sides of the stick to see that they're at the same level. Transmission fluid dipsticks can be real tricky sometimes.
lg3rd
May 24, 2017 09:13 AM
mattymax
Feb 28, 2017 06:57 PM
vandalizer
Aerostar
May 7, 2012 06:18 AM
billj6
1983 - 2012 Ranger & B-Series
May 10, 2008 06:42 PM
priv8pilot
Nov 18, 2006 08:56 AM
