Stroker motor question
Old Aug 20, 2003 | 07:15 PM
hybridf250's Avatar
hybridf250
Here's an idea I've been kicking around and I'd like someone's comments on.I pull in a stock class with a 472 cid limit. I was considering a 370 boring it .030" over and throwing a 4.5" stroker crank in it.This should make a 471. Would this be worth the time & money to build this or should I stick with the 460 stroke? Thanks.
Old Aug 21, 2003 | 09:15 AM
Dixie Pirate's Avatar
Dixie Pirate
Bore the 460 .060" and it'll be 473ci without the cost of the stroker crank.
Old Aug 21, 2003 | 03:11 PM
hybridf250's Avatar
hybridf250
I wasn't really worried about price, at least not right now. The main thing I need to know is which would be better, the long stroke and small bore or vice versa?
Old Aug 21, 2003 | 10:46 PM
Dixie Pirate
Since this is a pulling truck, a longer stroke will give you more torque. So I'd say you're on the right track to make more torque while staying within your class. Maybe later if you decide to go up you can use the 4.50" crank, some 6.70" rods and swap in new pistons and take it up to 557cid (or more depending on overbore)
Hope this helps
Mark
Old Aug 21, 2003 | 10:53 PM
Dixie Pirate
Sorry, I just remembered something pretty important. I think if you use the 4.50" crank you'll have to change the rods to 6.70". If not I believe the longer stroke on the crank will pull the stock rods out of the bottom of the cylinder bores.
Sorry about the brain fart in the previous post.
Old Aug 22, 2003 | 06:51 AM
ludis's Avatar
ludis
I'd think you'd want horsepower for pulling. In which case big bore short stroke is better. The big bore lets you get more air into the cylinders. You also might get a better rod ratio with the shorter stroke.
Old Aug 25, 2003 | 08:27 PM
ems844's Avatar
ems844
If your putting this in a pulling truck, then deffinately go for the long stroke!! Torque is the force that gets you moving, horsepower is just a side effect of torque. by going with a longer storke your going to get alot of torque down low to midrange, but the motors power band will start falling off at the higher rpms. since your pulling you more than likely wont be turning more than 4500 or so, so i would stick with the long stroke and you wont go wrong. if you still need more advice, just call up your local engine shop and ask them for advice. hope this helps you. EMS844
Old Aug 25, 2003 | 09:54 PM
Dixie Pirate
Like the man said
HP is good but torque is what moves you. For a good example....just look at diesel engines, they make relatively small HP numbers but loads of torque for pulling and hauling.
Old Aug 26, 2003 | 07:48 PM
bigsnag's Avatar
bigsnag
It all depends. Do they have RPM limits? Do they have gearing limits? If not then higher hp is the way to go. Think of it this way. If you could make 500 torque at 4000 RPM's or 500 torque at 8000 RPM's which would you want? 8000 RPM's. Why? Well, you can take the 8000 RPM engine and put twice the gearing in it and still be turning the tires at the same speed. Therefore you have effectively doubled your torque. Obviously the 8000 RPM motor would be considered a "hp" motor.
JJ
Old Aug 30, 2003 | 11:37 AM
mokicoolcruz's Avatar
mokicoolcruz
We have a "94" 460 F350. If we stroke and engine will the computer work or can it be tuned to work with a storke change? Would an aluminum Head transplaant make as much power with less Computer problems? Do I need a different block to go to a Roller Cam. Where would a guy find out what the codes stamped on the blocks. I've read an article that stated the 88 to 92 block is the strongest will it handle a roller cam or it this a true statement. There are alot of informative People in this group So I think I'm comming to the Best place for this info. We haven't call hot rod shops yet Mainly because they don't drive wht we do and maybe some of have what we want to try out. Expreince is the best teacher.
Old Sep 1, 2003 | 07:05 AM
76Econoline's Avatar
76Econoline
hybridf250, first I'd confirm that the 370 will take a 4.5" crank. I personally don't know, but to me 4.5" sure sounds like a lot of crank throw for that block.
