Help in Alaska!! Engine knock
Old Sep 13, 2016 | 09:16 PM
knottyrope's Avatar
knottyrope
That is great they figured it out and got it fixed fast. Not many good shops around that would do that. They would sell you a new motor for lots of coin.
Old Sep 13, 2016 | 09:31 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I'm so glad to hear it! I drive by Different Strokes every morning on my way to work, they work on A LOT of trucks and I hear many good things. I'm happy you are back on the road!
Old Sep 15, 2016 | 08:42 AM
HKusp's Avatar
HKusp
Man, that is truly amazing. These trucks are ridiculous...
Old Sep 15, 2016 | 08:32 PM
Jeremy05's Avatar
Jeremy05
We had a 00 7.3 at work and it sounded alot like that, it was number 5 as well. It eventually let go, i assume it cracked the cyl bore, because it dumped all its coolant into the oil pan. That was a close call on yours.
Old Sep 15, 2016 | 08:44 PM
z31freakify's Avatar
z31freakify
Why is it #5 cylinder the one to always give way? I ask because my engine on my OBS has the same knock on cyl #5, and also the long block I'm rebuilding had cylinder #5 with broken piston rings wich somehow travel to cyl #7 and destroyed that piston to? And none were dusted engines just plain ol work trucks.
Old Sep 15, 2016 | 09:39 PM
retiredsparky's Avatar
retiredsparky
Error in the fueling program from the factory? Timing is everything, especially over the long haul.
superv10
Arizona Chapter
Jul 18, 2014 01:41 PM
1950gmcelc
New Mexico Chapter
Mar 18, 2010 08:32 AM
HKusp
21
Aug 21, 2007 02:38 AM
jms
Escape & Escape Hybrid
Jul 30, 2006 06:29 PM
richard k
15
Jan 30, 2001 08:13 PM
