Front parking brake cable
Old Sep 2, 2016 | 09:07 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Exclamation Front parking brake cable
So, I've been searching for this damn front parking brake cable for the 67 (C7TZ2853D), with no luck. I can get the cable for the 2WD (C7TZ2853A). They are the same length, but, don't know the difference between them. Bill, Jeff, Got a clue on this one?
Old Sep 2, 2016 | 10:28 AM
JEFFFAFA's Avatar
JEFFFAFA
You are correct. They are listed as having the same length. I don't know what the difference is but the place I'm listing below shows the C7TZ2853D.
Klimesh Motor Sales
563-562-3241
Old Sep 2, 2016 | 11:29 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I can get it from several places, but, I'm just wondering if it has different attachments, or what.
Old Sep 2, 2016 | 12:26 PM
JEFFFAFA's Avatar
JEFFFAFA
I'm guessing it is the length of the cable's housing is different. The over all length may be the same but maybe not that housing. In the pic Ford shows the retainer bracket down on the frame side to be different. Prolly mounted in a different spot. So the housing could be a different length. Look at the right lower corner of this pic Pat.
Old Sep 2, 2016 | 12:44 PM
GaryKip's Avatar
GaryKip
Maybe it's another "67 ONLY" issue?
Old Sep 2, 2016 | 01:08 PM
JEFFFAFA's Avatar
JEFFFAFA
Good guess Gary but it isn't.
67/69 F100 (4X4) 77 3/4" long.....C7TZ2853D.
67/69 F100/250 (4X2) w/o 25 gallon frame tank 77 3/4" long.....C7TZ2853A.
67/69 F00/250 (4x2) with 25 gallon frame tank 80 1/16" long....C7TZ2853C.
Old Sep 2, 2016 | 01:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Gee whiz, I better edit, cuz El Jefje edited.
Last edited by NumberDummy; Sep 2, 2016 at 03:02 PM. Reason: Post edited with El Jeffe's correctamundo part numbers
Old Sep 2, 2016 | 02:07 PM
JEFFFAFA's Avatar
JEFFFAFA
But, the OP is asking for the front cable, not the rear ^ cables.
C7TZ-2853-D .. Front Parking Brake Cable - 77 3/4" long / Obsolete
Applications: 1967/69 F100 4WD
Ah. Thanks for catching that Bill. I edited the post. My info was correct except for the basic number. Got my head where the sun don't shine this morning.
Old Sep 2, 2016 | 02:27 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Yeah, I have that pic, Jeff. That's what I was wondering. Well, may have to just order it, and if it doesn't work, send it back. I'll have to be the guinea pig for you guys that may need this later!
Old Sep 2, 2016 | 03:00 PM
NumberDummy
I edited my post to reflect El Jeffe's edit.
Old Sep 2, 2016 | 03:14 PM
JEFFFAFA's Avatar
JEFFFAFA
I don't understand Pat. If you are getting the NOS one why wouldn't it work?
Old Sep 6, 2016 | 07:12 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
The one I found that's available is for the 2wd, and I have a 4x4. I guess we'll see what the differences are when I get it.
Old Dec 1, 2024 | 04:41 PM
Kowality's Avatar
Kowality
2nd Gear
Still out there
Just found this thread from 8 years ago, but I am currently in the same boat. I would really like to know how this ended.
Thanks!!
Old Dec 2, 2024 | 01:38 AM
Green72F250's Avatar
Green72F250
Here is a breakdown of the different part numbers and lengths for the parking brake cables, maybe this will help. It has both front and rear cables listed.
Ford Truck Part Numbers (PARKING BRAKE CABLES - REAR) - FORDification.com
Old Dec 2, 2024 | 03:42 PM
Kowality's Avatar
Kowality
2nd Gear
Yep, appreciate it and have all that, the problem is the 72 4x4 cable is not called out. NUKEFORD was trying the 2WD cable and that is probably what I will have to do too. Interested to see if it worked or not.
