which setup
Old Aug 20, 2003 | 04:08 PM
fordeverpower's Avatar
fordeverpower
which setup
I have a 390 witha 2bbl and I want to upgrade it. I would like the Edelbrock performer intake and there 600 cfm carb. That cost a total of $500+accessories. Or I thought about running a 500cfm 2bbl on the stock intake for $220+acc. What should I go with? I'm sure the 4bbl setup makes more power but how much more then a 500cfm would.
Old Aug 21, 2003 | 12:25 AM
fordeverpower
which setup
I have found out that there are adapters for 4bbl carb to 2bbl intakes but who has them?
Old Aug 24, 2003 | 11:32 PM
LxMan1's Avatar
LxMan1
which setup
Using the adapter is like pouring 90w gear oil thru a funnel. You can only flow so much thru the 2 holes.
You will gain performance and gas mileage with the 4bbl(if you keep your foot out of the secondaries) because you will actually be running off of the front 2 barrels most of the time which are actually smaller than the two barrel venturies.
Plus you will lose about 75lbs off of the engine by going aluminum. Less weight to pull means more performance.
Jimmy
Old Aug 25, 2003 | 08:11 PM
fordeverpower
which setup
yeah but is the $240 and the pushrod hassle worth it.
Old Aug 26, 2003 | 10:21 PM
LxMan1's Avatar
LxMan1
which setup
It's all personal preference. I'm always up for a challange, But I admit, the FE motors are a pain!!
Jimmy
Old Aug 27, 2003 | 02:42 PM
Superdave's Avatar
Superdave
which setup
fordeverpower
Years ago I put a Holley 500 cfm, 2bbl on a 390 (with the stock cast iron intake) to replace the Motorcraft 2 bbl.
It was a direct bolt on and it helped the performance "tremendously".
Did not hurt the fuel mileage any. But it already was bad anyway.
