Sponsored by: Real Truck
Switch Panel
Old Aug 30, 2016 | 08:48 PM
ligito's Avatar
ligito
Switch Panel
Nice and cheap, I just got mine, today.
May not work here but I wish I had found one of these, years ago.
//https://www.amazon.com/TurnRaise-Waterproof-Breakers-Cigarette-Voltmeter/dp/B01FO2YXF6/ref=sr_1_2?s=boating-water-sports&ie=UTF8&qid=1472607918&sr=1-2
Old Aug 31, 2016 | 04:38 AM
Pocketlint's Avatar
Pocketlint
I am sure there are a few folks who are going to like this. Cant say I have spotted one like this with that many switches plus usb and charger port along with the voltmeter, looks like a good score.
Now the real question what are you planning on doing with it?
Old Sep 1, 2016 | 12:01 AM
ligito's Avatar
ligito
Going to try to customize an F650 lower panel, to accommodate it.
Old Sep 1, 2016 | 03:54 AM
Pocketlint's Avatar
Pocketlint
You'll have consider posting up some pics as you go along and of course the final results. Always interesting to see how folks go about mounting em,where people mount them and how they hook em up and of course what they hooked up to the switches.
Being that this panel has a little size to it, should give you a few challenges , but looks like your up for the challenge. Keep us updated if you can and have the time as your project moves along
Old Sep 1, 2016 | 09:53 AM
ten4rd's Avatar
ten4rd
ah thats cool i like that
Old Sep 1, 2016 | 02:51 PM
ligito's Avatar
ligito
I have some smaller panels on the way.
I want to have several options.
I didn't know that some of this technology even existed.
I will post pictures, when I have a plan formulated.
Old Sep 4, 2016 | 05:38 PM
ligito's Avatar
ligito
I put the F650 panel in my F250, to see how it looked.
The part with the vertical rectangular hole invades the leg area too much, where a middle passenger would sit.
I don't like this, so I will modify the stock panel.
I will mock up the panel and take some pictures, as I progress.
It won't be a quick job.
Old Sep 4, 2016 | 06:48 PM
WE3ZS's Avatar
WE3ZS
It sounds like you have the F-650 Auto trans dash panel, have you tried the other Manual trans F-650 panel? It doesn't drop down towards the foot area of the center passenger but it has more flat area for switches and such than the stock SD dash panel.
Old Sep 5, 2016 | 11:52 AM
ligito's Avatar
ligito
I'd like to see a picture and a part number of that.
Old Sep 5, 2016 | 12:24 PM
WE3ZS's Avatar
WE3ZS
Take a look at this thread, it has both pics and part numbers for the dash panel.
https://www.ford-trucks.com/forums/1...f650-dash.html
Old Oct 28, 2016 | 06:28 PM
ligito's Avatar
ligito
I ran my 8 Ga. wire through a plastic pass through that I found under the dash.
From under the hood, it can be seen on the driver side,.
It's parallel to the brake shaft, about 6-8 inches closer to the fender.
Under the dash, it can be seen behind a pop-out panel in the insulation.
I drilled it from under the hood, with a long drill bit, then made it bigger, from the inside.
I ran it through about 12 inches of plastic air brake hose, just to protect it through the firewall
and then used split loom and ran it across to the passenger side and up to the battery.
I'll add more pictures as I go.
Old Nov 5, 2016 | 07:39 PM
ligito's Avatar
ligito
New battery terminals.
The old ones were of the bolt onto the cable type.
The new 8 Ga. cable that feeds the new fuseblock, uses a 60 Amp Maxi fuse.
Old Nov 5, 2016 | 07:42 PM
ligito's Avatar
ligito
This is the Blue Sea 8 position fuseblock that I bolted to ABS plastic and then bolted that to the lower dash surround.
Old Nov 5, 2016 | 08:54 PM
HearseDriver's Avatar
HearseDriver
Thanks for sharing, the updates & pictures. I also want to ad a constant hot fuse block in my truck so your ideas, pictures & posts worked out Great for me.
Old Nov 6, 2016 | 12:08 PM
ligito's Avatar
ligito
Next time, I'll add a picture of the underhood wiring route.
I also have a ground block that I'll add to the inside.
