Sponsored by: Real Truck
Switch Panel
Old Nov 6, 2016 | 07:06 PM
ligito's Avatar
ligito
Blue Sea ground block.
Old Nov 6, 2016 | 07:08 PM
ligito's Avatar
ligito
Hella TDR (Time Delay Relay). The time delay is adjustable.
I am using a Carling momentary switch to turn on the Hella TDR timer, which then powers the heated mirrors, that way, I don't have to remember to shut the
switch back off.
I set the TDR for close to the maximum of 15 minutes. I haven't timed the cycle, to see exactly how long it is staying on.
Old Nov 8, 2016 | 11:06 AM
ligito's Avatar
ligito
Ground block without cover.
I will put the cover on after the wiring is finished
Old Nov 9, 2016 | 01:53 PM
HearseDriver's Avatar
HearseDriver
Thanks again for the updates and pics. I did add Upfitter switches to my 06 but I still want an inside constant hot. I also plan on doing the same for a Key On hot - Tripped by 40 Amp relay by the "Cust Access" fuse. On my 06 it's a 10 Amp circuit - a white wire with a teal or bluish stripe capped off in the area behind the cup holder.
Old Nov 9, 2016 | 04:18 PM
ligito's Avatar
ligito
I installed the panel, today and wired some connections.
Got tired and quit for the day.
More, tomorrow.
Old Nov 23, 2016 | 06:15 PM
ligito's Avatar
ligito
I got it all back together and reinstalled the Nav unit.
I added a switch on the far left to turn off the voltmeter and the LED in the double USB charging port.
The left rocker turns on the Time Delay Relay for 15 minutes, to heat the mirrors.
The right rocker turns off the LED in the other USB charging port.
There is a power port on the right side of the smaller panel
The covered port to the right of the upper panel, houses a USB and HDMI input for the nav unit.
I will work on the original panel, over the winter and may, or not, install it later.
This works and I may just keep it.
I'm just relieved that I can finally put all of the kick panels etc., back in place.
Old Nov 24, 2016 | 04:26 PM
Projectlittleredf250's Avatar
The covered port to the right of the upper panel, house a USB and HDMI input for the nav unit.
What radio/ nav unit do you have/ how do you like it ?
Old Nov 24, 2016 | 06:12 PM
ligito's Avatar
ligito
Kenwood DNX-893S
It was just installed again, yesterday, and I don't even have everything setup.
It has to be better than my Pioneer AVIC-6000.
Old Nov 25, 2016 | 05:43 PM
ligito's Avatar
ligito
I did some setup today.
It seems to have better control of options.
I'm hoping this one will get rid of, or control, the over speed limit nag.
I turned the volume down for the navigation and I'm hoping that will work.
I drove it today and didn't hear any nags.
My Pioneer is a constant nag, it even nags in zones that are higher than the posted speed limit.
Powerhour
1947 and Older Ford Trucks
Jun 4, 2017 10:23 AM
kc0stp
Mar 4, 2013 09:35 PM
bobj49f2
Jul 10, 2006 12:23 PM
Campbell 56
Feb 16, 2006 03:53 PM
