Bed width 1970 vs 1977
Old 08-30-2016, 03:36 PM
Matt1966's Avatar
Matt1966
Matt1966 is offline
I found a used Truck Tool Box from a F100-70. Can you help me out here and answer
if it's going to fit the bed on my F150-77? (Styleside) Is the -77 bed some wider?
Thanks!
Old 08-30-2016, 04:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
According to the 1970 Ford body builders manual, the bed, measured at the top of the bed, inside to inside is 65" wide. Outside to outside is 76".
Old 08-30-2016, 04:59 PM
Matt1966's Avatar
Matt1966
Matt1966 is offline
Thanks!
Can you find out the -77dimensions as well? I am far away from my Truck at
the time.
Old 08-30-2016, 05:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by Matt1966
Thanks!
the time.
Sure, the '77 dimensions are pretty much the same. The body builder's manual (I'm actually using a '76) says inside to inside is 65" and on the outside dimension, it doesn't measure at the outside edge of the bed rail. it gives the measurement at the widest point of the body which is 79.06". But, for you, I think the inside is the important dimension.
Old 08-30-2016, 05:25 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Basically every full size ford truck has the same 65" inner bed width. My 71, 77, and 99 super duty are all the same. I know even the newer super Dutys are that way. Not sure about new F150.
Old 08-30-2016, 05:37 PM
Matt1966's Avatar
Matt1966
Matt1966 is offline
Perfect! Thanks a lot mikeo0o0o0 and 351Cleveland C4
I like the look of the old Truck Tool Box (steel not alu) I found but wasn't sure if it would fit my Truck.
clhart426
09-10-2010 04:21 AM
78f250lj
01-28-2010 12:32 PM
Fordtruck51
06-01-2009 10:58 AM
bmyrda
05-19-2008 07:47 PM
Thoth88
04-16-2004 05:29 PM
Quick Reply: Bed width 1970 vs 1977
