1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Axle or Calipers + bleeder valve issue?
Old 08-30-2016, 02:51 PM
bmbsqd's Avatar
bmbsqd
bmbsqd is offline
2003 F-250 SD 7.3L Supercab
Problem 1: Right rear
Occasional smell of heavy grease, white smoke billowing out from under wheel well (once), black fluid leaking from lower area of caliper. Told it could be axle seal or caliper. I'm leaning toward axle since the caliper is only 1 yr old (NAPA OEM).
Oddly, I also notice a loud, piercing sreech when going around traffic circles or exit ramp clovers to the right. I thought this was my trailer until it did the same thing without it.
Axle or Caliper?
Problem 2: Left front
Local mech advised the bleeder valve is broken off in to the unit and cannot be simply replaced. Insists it needs whole caliper. If pedal is all the way up there is a temporary breaking capability then it slowly creeps to the floorboard, hits a brick, and keeps rolling. Replaced master cylinder a few months ago when it same. Drove it for the last 2 weeks and problem is back.
Anyone have experience removing broke-off bleeder valve instead of replacing cals?
Thanks in advance!
Old 08-31-2016, 03:36 AM
finn's Avatar
finn
finn is offline
Replace the caliper.
It's not worth screwing around with a rusty caliper ..
Besides, the pistol is probably sticking causing the pads to drag about now anyway.
Calipers are relatively cheap.
Old 08-31-2016, 04:27 AM
Pocketlint's Avatar
Pocketlint
Pocketlint is offline
Seconded. Your better off to just replace the caliper. You could mess around with the bleeder but if the fix doesnt take, your back in the same spot. As suggested above calipers can be cheap, might not be as cheap as trying to replace the bleeder, but if your replace the caliper, you shouldnt have to worry about that one for a long while
Old 08-31-2016, 09:13 PM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
You need to replace the caliper and bleed entire system, you may need a high end scanner that can do a service bleed, as you may have air in the ABS system. It also sounds like you may have a defective master cylinder, but I would fix the caliper and bleed first.
redford
05-17-2017 11:52 AM
Fordf25091
20
09-08-2014 06:38 AM
t_jones792002
6.4L Power Stroke Diesel
11-03-2011 07:21 PM
99StrokeXLT
02-25-2011 04:22 PM
F250maniac
08-17-2008 07:20 PM
Quick Reply: Axle or Calipers + bleeder valve issue?
