Front Bearing assembly
Old 08-30-2016, 09:58 AM
MoBill122's Avatar
MoBill122
MoBill122 is offline
Papa Smurf
2001, F250, 4x4, 432,000 miles...
Seems this truck eats up bearing assemblies. Anyone else have that problem? Its like every 2-3 years, I'm having to replace one side or the other. And we talking like 30-40,000 miles.... gezzz
What brand you guys think is the best ?
BTW.... although I'm not out doing much 4x4 driving, this truck does do a lot of dirt roads, probably over 50%...
Old 08-30-2016, 11:36 AM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,206 Likes on 829 Posts
How's your ball joints? Worn out ball joints can stress the hub bearings.
Old 08-30-2016, 11:59 AM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Our you greasing the bearing before you put them in? You need to use high quality grease. And are the stub shafts in good condition? They will take out bearing also. Timken bearing are what most use.
Old 08-30-2016, 01:29 PM
MoBill122's Avatar
MoBill122
Papa Smurf
I'm guessing ball joints are ok, since I get it lined up and they haven't told me they were messed up. Tires wear normally.
Its a hub bearing assembly, self contained, you just bolt it on. Its sealed up. No water in the 4x4 hub side either.
Old 08-30-2016, 01:39 PM
Bonanza35's Avatar
Bonanza35
You still have to grease the bearing before you bolt them up. This is very important. Use high quality grease to do this. Just push it in with your finger all around and your good to go. That's if the stub shaft is good to.
Old 08-30-2016, 01:53 PM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
I believe you are both talking about two different bearing assemblies. You are (I am assuming) talking about the needle bearing, and yes, this does need to be packed with grease before install. I believe he is referring to the main hub bearing? Which is indeed greased from the factory.
Just trying to help clear up some confusion....
Old 08-30-2016, 02:04 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
your signature indicates "stock" are your rims stock and stock size tires ?
how many miles would you estimate you spend on dirt roads ?
fwiw, I spend a good deal of time in the desert in Baja mexico and i ditched the stock unit bearings in favor of a serviceable wheel bearing setup because the sealed unit bearings don't last long off road.
I used to carry a spare hub assembly with me, now I just carry a bearing set.
jlatr
02-11-2016 04:33 AM
sillyjt
07-28-2012 09:29 PM
kbarger1
04-11-2007 12:06 PM
Jim59
1999 to 2016 Super Duty
10-10-2006 06:35 AM
95f150
05-07-2005 11:00 PM
Quick Reply: Front Bearing assembly
