Misfiring 223
Old Aug 29, 2016 | 10:39 AM
mackedisto's Avatar
mackedisto
Misfiring 223
Hello, I am trying to resurrect a 1962 F-100 with a 223 and manual transmission. The previous owner had the engine rebuilt by students at a institution about 7 years ago and said it ran fine. It has been parked since then until I got it. I replaced the fuel tank and lines due to rust and rebuilt the single barrel carb. The problem I am having is that it continually fouls out the #1 and #5 plugs. The only thing I can find they have in common is they are next to each other in the firing order. I have replaced the cap, points, condenser, wires, and plugs. I can swap the plugs with those I know are firing and after a couple minutes they start to foul out again. There's not a lot of smoke though there is a little initially on start-up. The only thing else I can figure is the distributor itself. If its shorting out why is it just on 1&5? Could it be a bearing in the distributor? I'm at a loss, If I had any hair I'd be pulling it out already. Thanks in advance.
Old Aug 30, 2016 | 11:11 PM
tinman52's Avatar
tinman52
Welder User
Plugs oil fouled or gas fouled? If gas, likely an ignition problem. If oil, likely a stuck ring.
Have you done a compression test? Does it misfire when those 2 plugs are clean?
80'BUB
Jan 22, 2017 04:51 PM
Catfish369
Bronco II
Sep 12, 2004 10:04 AM
Gates
Sep 13, 2002 05:59 AM
fahad
Jun 26, 2002 04:46 PM
Peabody
Feb 22, 2002 10:08 AM
