Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
po136 code
Old Aug 28, 2016 | 05:08 PM
fordboy67's Avatar
fordboy67
po136 code
Wife's 04 Escape threw the PO136 code for bank 1 sensor 2 02 sensor. Replaced it and light is off. Not convinced something else isn't causing it. Thoughts?
Old Aug 29, 2016 | 10:12 AM
tomw's Avatar
tomw
Bank 1 or bank 2 sensor 2 (for a V type) do the same thing. They monitor the output of the catalytic converter to check that it is working. Inside the converter, there is oxidation and reduction going on.{chemistry terms about add/remove O2} The computer knows what is coming in, knows the gas 'content' from sensor 1, and 'knows' what the result should be with a 'good & functioning' converter. Most times the sensor 2's are 'just along for the ride' until the catalytic converter is poisoned, and then they throw codes.
It is an unusual failure, from observation of 'things' in the FoMoCo area. Both sides are the same, bank 1 & bank 2, but the wire length may differ. I think sensor 1's are the same, again with lenght or terminal differences. If you get a 'generic', it will have bare wires and you get to re-use your plug connector, after cutting, stripping, etc.
tom
Old Aug 29, 2016 | 01:53 PM
projectSHO89's Avatar
projectSHO89
Drive it and see what happens over time. It's fairly useless to guess about what *might* happen.
Old Sep 2, 2016 | 03:12 PM
52caddy's Avatar
52caddy
I have the same thing on my 03. But when I look at the reading for bank 1 sensor 2 I get a consistent 0 volts. I pulled the pug apart, cleaned it up and checked the wiring and everything looked good. I had 12 VDC on the white wires, any ideas if there's a way to read the actual voltage off the sensor instead of thru the computer? That way you'd be able to rule out the wiring.
I'm thinking of replacing it and seeing what happens.
Teager
Mar 28, 2024 11:44 PM
reptar0077
Jun 16, 2019 02:57 PM
nut1605
Jun 8, 2019 10:25 AM
a3mariner
May 23, 2015 04:33 PM
1998Ranger25L153CID
May 10, 2011 06:55 AM
