Phase II of sound dampening
Finally got started on phase II of sound deadening the ex (two years after phase I).
Phase I:
-Dynamat extreme plus Dynamat dynaliner roof
-Dynamat extreme in all doors
-Dynamat extreme and Dynamat hood liner on the hood
Phase II:
-Dynamat extreme floor
-Dynamat extreme rear side panels
-Dynamat extreme firewall and dash panel plus Dynamat 4-layer firewall liner
Most of the interior gutted and cleaned...
FYI, dynamat is more of a rattle stop. if you want sound dampening or sound absorption you need a diffrent product it is pretty common to see dynamat misused as a sound dampener though. Read the directions and they even tell you this.
A sound absorption mat is going to be more like the padding stuff you see under your carpet or the mat they attach to the hood and firewall.
One of the biggest areas you can improve on the excursion is the wheel wells. If you look at the inside of the plastic that covers the wheel wheels on the interior you will see sound blanketing. You can buy that stuff and add more to the wheel wells. ( thick moving blankets work as well as it is the same material )
Yes - I have liner as well - the whole system. Dynamat extreme does well at reducing the tinny sounds and make the environment more relaxed even if sound levels are not significantly reduced. Phase 1 of my project made a noticeable difference making the cabin feel calmer. Another benefit of the liner is heat insulation - especially with the roof done - making it quicker to heat in the winter and quicker to cool in the summer. I especially noticed how easy it is to heat up the cabin in winter.
Every I've ever been in is noisy. Sounds from the engine compartment, the transmission, body mounts and road noise.
On the other hand, the driveshaft, wheel bearings and pumps (steering, water, etc.) are noticeably quieter...until they aren't.
