Sponsored by: Real Truck
Cooling tank replacement questions
Old Aug 27, 2016 | 01:04 PM
Jaime74656's Avatar
Jaime74656
Just curious, I know the coolant bottle on my truck is three bolts (already had them in done once for compressor work) but I am going to replace the tank it is rather yellow and I am concerned that it will fail soon and cause more issues, how hard is it for draining the coolant? Is there a plug that I can use perhaps at the radiator that will let me drain the tank that way?
Old Aug 27, 2016 | 02:18 PM
r2millers's Avatar
r2millers
I just plug the tubes with either a #2 or #3 Phillips screwdrivers to stop any flow. Easy to replace the tank without issue.
Old Aug 27, 2016 | 02:21 PM
Wealthk1's Avatar
Wealthk1
It's a real easy replacement. Just make sure the bolts are out first before removing the lines, Make sure the cap is on and just tilt it towards you as you are taking it our to minimize losing much fluid out of the tank.
Old Aug 27, 2016 | 02:25 PM
Jaime74656's Avatar
Jaime74656
ok cool, thats what I was thinking, but figured I would ask first
dcgayhart
Jan 28, 2018 05:43 PM
Mervy49
Dec 27, 2012 10:07 AM
srqdiesel chef
May 14, 2010 11:24 AM
tommyl
Mar 16, 2007 09:53 AM
workingdog
13
Oct 21, 2006 10:45 PM
