Why is this a problem? This is what they had at Tractor supply and I suspected it might not be the right stuff. Depending on your reply I might be draining my system and replacing all the coolant.
Tractor supply has concentrate. That's where I get it. Walmart has the premix which is fine for topping off a system already running the Rotella ELC.
Now, As long as the system already was running Rotella ELC, it is fine to refill it with the Walmart pre-mix Rotella ELC.
BUT, If you flushed your system with destilled water then you start your first fill with concentrate Rotella ELC. Reason being is the block holds a few gallons of water. So to compensate you fill it with concentrate initially. Anything after that you fill with premix.
