Shackle Pin Lock Pin
It can be a challenge.
Be sure your shackle pins are lined up right. There is a notch in them and that has to line up just right. Also make sure the notch piece in the lock pin is lined up with the notch in the shackle pin.
I don't think the grade 8 bolt would be a good option, but farmers did just about anything to keep trucks running.
Make sure that the pin is rotated so that when you drive in the lock pin the rib on the lock pin will go into the slot of the shackle pin not hitting the side of the pin. If you have the shackle pin rotated a little too far, the lock pin will turn it as you drive it in. If you don't have it rotated quite far enough, the lock pin will butt against the side of the shackle pin and not go in. I hope that makes sense.
Mark
Mark
82Y-5782 .. Rear Spring Shackle Pin Locking Pin - 3/8" -24 x 1 3/4" long / Obsolete
Misc. applications: 1948/52 F1/F3 / 1953/56 F100/350.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
KLIMESH MOTOR SALES in Calmar IA has 6 = 563-562-3241.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 8,277 (!) = 800-476-9653.
The following users liked this post:
tomrflorida
10-03-2012 12:17 PM
