F-350 problems
Old Aug 24, 2016 | 10:45 AM
Rikster-7700's Avatar
Rikster-7700
Never mind........
Old Aug 24, 2016 | 10:53 AM
PNW350SD's Avatar
PNW350SD
Huh?
Did I miss something?
Old Aug 24, 2016 | 11:27 AM
knottyrope's Avatar
knottyrope
Originally Posted by PNW350SD
Seems I may also change the EBP sensor and clean the tube.
I didnt realize this is so critical.
I ended up replacing the tube with brake line, snaking it out took longer and couldn't get past the last 90 bend which was plugged solid
Old Aug 24, 2016 | 11:29 AM
Rikster-7700
Huh?
No, I mistyped, but still need to have something there for the character count on editing.
Old Aug 24, 2016 | 12:12 PM
PNW350SD's Avatar
PNW350SD
Can someone pinpoint where the IDM relay is on my 2000 f350?
Relay number?
Also what relay number to take out and swap in it place to see if it solves my non starting issue.
Old Aug 25, 2016 | 10:36 AM
PNW350SD's Avatar
PNW350SD
I replaced the IPR and the EBP Sensor. My tube has a crack in it so I will order a new one and replace it.
I also picked up two new batteries and replaced the CPS back to the new Napa version, after I had tried to install my original to fix the no start issue initially.
I also replaced most of the Maxi fuses as a lot looked to be tired.
Finally I found a chafed wire going to the CTS that is located on the water pump.
The wire was chafed where is connects back up to the rest of the wire loom where the four front sensors (CTS, CPS, EBP, HPOP) come together over the front portion of the passenger side VC.
Idk if that would effect my truck but I repaired the damage.
The truck fired right up. Literally. I primed the engine 3 times.
I pulled some information from my SCT Livewire while sitting at idle, truck partially (1/2 way) to operating temp. Sorry for lack of metric(s), i just took the information straight from the screen.
load: 11.75
ICP duty cycle: .09
Injector Control Pressure (Mpa): 3.47-.50 = 503 PSI
Injector pulse width: 2.69
Any feed back on these numbers would be great and highly appreciated.
I am going to hunt down the parasitic drain this weekend.
Old Aug 25, 2016 | 10:54 AM
coax9952's Avatar
coax9952
It looks like your back to normal, normal.....I would scour your wiring for more busted wires. Where there's one there will be more....
Those numbers are pretty much stock/normal
Old Aug 25, 2016 | 11:09 AM
PNW350SD's Avatar
PNW350SD
HAHAHA,
Thank you very much for the response. I will be looking into the wiring loom more.
That being said does anyone here have a SCT Livewire TS 5015 for their 7.3?
I cannot for the life of me find out how to monitor boost?
Please talk to me
Old Aug 25, 2016 | 12:10 PM
knottyrope's Avatar
knottyrope
you can tap a line off the MAP sensor port and put a gauge in
use a mobile app with a BT ODB reader for under 30 dollars to read the MAP PID
Old Aug 25, 2016 | 02:45 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
IDMs rarely go bad. They do, however, get water in the plugs sometimes that will cause a bad connection between it and the PCM. Like from the wiper fluid leaking down onto it after a windshield change where the sprayer was broken and nobody told you they broke it...
As mentioned here already, white smoke indicates your injectors are pushing fuel to the cylinders. You are seeing it come out the tailpipe. This should mean the IDM is working to some degree. Have you opened up the turbo to check the compressor fan blades for signs of dusting/damage?
Did you check the PCM/fuel bowl heater fuse yet?
EDIT: just saw you got it running. Great!
Old Aug 25, 2016 | 04:47 PM
dn29626's Avatar
dn29626
The suggestions I would make have already been covered.
Welcome to FTE.
Old Aug 25, 2016 | 08:25 PM
countrycar's Avatar
countrycar
load: 11.75
ICP duty cycle: .09
Hey just wondering, what is the CTS sensor?
Old Aug 26, 2016 | 05:15 AM
  #28
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
If it is located on the water pump, it must be a Celsius Temperature Sensor 😂
Old Aug 26, 2016 | 10:31 AM
  #29
coax9952's Avatar
coax9952
I think He fat fingered CPS.....
Old Aug 26, 2016 | 11:16 AM
  #30
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I was thinking coolant temp sensor since it was on the water pump.
