Brakes
Old Aug 22, 2016 | 05:42 PM
Bearhugger1933's Avatar
Bearhugger1933
Brakes
Ok guys,where can I get a new abs valve,these brakes are killing me.
Thanks jim
Old Aug 22, 2016 | 06:27 PM
knottyrope's Avatar
knottyrope
rockauto.com has rman ones for 156
Old Aug 24, 2016 | 02:38 PM
79jasper's Avatar
79jasper
Pretty much everywhere sells them.
I would just go with the cheapest.
Is yours rusted out? Or?
Old Aug 24, 2016 | 02:50 PM
PSU4ME's Avatar
PSU4ME
i ordered the reman one from Rock auto....$106 after you send the core back
Old Aug 25, 2016 | 10:39 AM
Bearhugger1933
Thanks guys,I,m working on it right now.
Jim
Old Aug 25, 2016 | 06:42 PM
ReBilld's Avatar
ReBilld
Thanks jim
I'm gonna bypass mine. The ABS on these trucks is the biggest joke I've ever seen. My brakes suck too. Every thing new on the rear, new pads and rotors on the front, swapped the valve, module, master and booster out of three other trucks......brakes still suck. I tow heavy, and at times, VERY heavy. If I have to make a panic stop while towing heavy with my goose neck trailer, I WANT something to lock up and stop me! LOL!
Old Aug 25, 2016 | 08:16 PM
Bearhugger1933
You are sure right,this brake system sucks and I had a 1992 that was just as sorry.I was looking under mine today and it looks like mine has two abs valves,one on frame under front door and one on frame under back door,didn't know these things came with two,will look some more tomorrow,don't know how we got along for so long before ford put this mess on them.
Old Aug 25, 2016 | 09:35 PM
ReBilld's Avatar
ReBilld
Only one. The one toward the rear is the tank selector valve.
Old Aug 25, 2016 | 09:43 PM
Bearhugger1933
Thanks Bill,I didn't, think about that,now I won't have to crawl under there's again,getting too old.
Jim
Old Aug 25, 2016 | 09:46 PM
ReBilld's Avatar
ReBilld
Jim
LOL!...........
Old Aug 25, 2016 | 09:49 PM
fordpride's Avatar
fordpride
Y'all just need to find the issue. My truck will put your face in the dash. Just cause parts are new doesn't mean they're good.
Old Aug 25, 2016 | 09:52 PM
ReBilld's Avatar
ReBilld
I found my issue........the drum brakes on these trucks SUCK! LOL!!!
Old Aug 25, 2016 | 09:54 PM
fordpride's Avatar
fordpride
Test the RABS valve to make sure it's good....new doesn't necessarily mean good. There is a big hex plug on one end of the valve...takes about a 1 5/16 wrench (crescent wrench size). Some have a little rubber plug in the middle, some don't. Behind this hex plug, you'll find the accumulator spring and the backside of the accumulator piston. If you've got the little rubber plug, pull it out and stick a piece of stiff wire in there until you hit the back of the piston...then have someone fire up the truck and bury the brake pedal....if the piston pushes your piece of wire back out of the hole, then the dump valve is stuck open/leaking and the valve assembly is shot. If you don't have the rubber plug...just unscrew the big hex plug and remove the spring...hold a screwdriver agaisnt the back of the piston for the test.
Old Aug 26, 2016 | 05:08 AM
Joey Fletcher's Avatar
Joey Fletcher
Got an easier way to check it all.
4 C-clamps
Gently clamp off all 4 flex lines. there is only one flex line to the rear brakes and a larger soft hose going to the RABS.......that will be the 2 lines on the rear end housing.
The front has a flex line to each caliper.......remember do not try to crush them ....the ID. is only 1/8 inch
start the truck and mash the brake petal.......it should be hard as a rock......if not you have an issue with the master cylinder.
next remove one C-clamp at the time starting in the front..........if petal is still hard install the clamp back on the line and move to other side.
Continue to check all 4 hoses one at the time....you should find where there is air in the system
ReBill.........You have a PVT. message
Old Aug 26, 2016 | 04:23 PM
Bearhugger1933
Thanks guys,all info is appreciated,going to keep on this thing.
Jim
