Carter Carburator...
Old Aug 21, 2003 | 02:06 PM
BB's Avatar
BB
Wait, I didn't tell you what wire it is. Just need to know if you got a gauge.
Barry
Old Aug 21, 2003 | 02:10 PM
BB's Avatar
BB
Originally posted by luckild
if the truck had an electric choke,some where in the harness close to the choke should be the connecter.
Yes but that is for Ford's electric assist choke. It operates at a lower voltage (half the charging voltage) that comes off the stator on the alt. Aftermarket electric chokes need a full +12 volts to work correctly. I know I'm gonna hear it form people that have hooked it up that way but it's not right.
Barry
Old Aug 21, 2003 | 04:42 PM
txwing's Avatar
txwing
OK... so.. "Who's on First"? : )
No really.... I'm getting confused now.
I will take pictures of what I got. And tomorrow I wil post it somewhere and if you all can please continue tomorrow, that'll be great!
Old Aug 21, 2003 | 05:02 PM
BB's Avatar
BB
Ok I'll wait, the post count on this thread is already getting way too high for such a simple thing, like how many posts does it take to change a light bulb!
Barry
Old Aug 21, 2003 | 05:07 PM
txwing's Avatar
txwing
Funny!...
(I guess I DO have an "idiot" light... in my head.)
Old Aug 22, 2003 | 08:50 AM
txwing's Avatar
txwing
OK, here are the new pictures. It includes some close-up photos so you can see the wiring I got. Please let me know if you can help me with these. 71 f100; 300-6
http://home.villagephotos.com/2003-8/21002/NEW%20PICS/
txwing's Avatar
txwing
Old Aug 22, 2003 | 09:09 AM
GolferSA's Avatar
GolferSA
My biggest concern is that you're putting a Chevy carb on a Ford truck!
Old Aug 22, 2003 | 09:20 AM
txwing's Avatar
txwing
WHAT!
I don't know about that... it's that same carb that was on the truck when I got it. What's the difference of a Chevy & Ford carb? Don't they do the same thing?
What should I get then?
Old Aug 22, 2003 | 09:27 AM
GolferSA's Avatar
GolferSA
I was just jerking your chain a little, don't be alarmed... the Carter will work fine, good reliable carb. Ford's typically carried Autocraft or Holley carbs, Chevy's typically had Carter's. All will meter the air to gas ratio correctly and the truck will run fine.
Old Aug 22, 2003 | 09:46 AM
txwing's Avatar
txwing
Whew.... almost gave me a heart attack!! : )
(BTW Nice truck)
Old Aug 22, 2003 | 03:48 PM
BB's Avatar
BB
Hey thanks for taking all the pics. Damn, you got idiot lights, that makes it a little harder. What I need is a pic of the back of the ignition switch with the wires and everything to show you where to tap off of. We're looking for switched power that is on only in the run position. Or, what about converting the choke back to manual and using the choke control?
Barry
  #28
txwing's Avatar
txwing
Hello Barry... you there?
Please help.
Old Aug 22, 2003 | 03:51 PM
  #29
txwing's Avatar
txwing
Looks like we posted at the same time... Sorry.
I thught about making it manual again... but I don't want to mess with it and regret it later.
Can I use a cable that's in in the same hole as the choke cable.
See pick:
http://home.villagephotos.com/2003-8...able-close.jpg
Old Aug 22, 2003 | 03:53 PM
  #30
BB's Avatar
BB
OK, if you could get some pics that would help.
Yeah, you could use that cable. Check to see it's not frozen.
If you get a pic of the ignition switch, all I need to see is the bottom part that you could see by sticking your head under the dash.
Barry
