steering box adjustment
Old Jan 11, 2002 | 10:06 AM
mayerst's Avatar
mayerst
Post steering box adjustment
After reading some of the posts I have seen some references to steering box adjustments. I have a 1995 F-150 5.0 lt w/auto. Can some one describe the procedures to adjust this box? In advance thank you.
Tom
Old Jan 11, 2002 | 10:53 AM
GammaDriver's Avatar
GammaDriver
From what the alignment guy showed me a few weeks ago, there is a slotted screw that is held in place by a lock-nut. The slot is for a large screwdriver.
Unlock the nut that locks it in place, the turn down the screw a little.
What you're doing is meshing the steering box's gears back together. They develop some distance betweeen one another due to use and wear.
Careful here - making it tight will bind up your steering a little. Just turn it down until you feel pressure, then hold the bolt in place (with the screwdriver) while you re-lock it with the nut.
Old Jan 11, 2002 | 12:32 PM
chris112lee's Avatar
chris112lee
after tightening it back it off!! very important or else your gears will wear down fast. back it off an 1/8 turn after you tighten it completely
Old Jan 11, 2002 | 01:50 PM
PAUL_2's Avatar
PAUL_2
Make sure all the other steering parts are not worn before you go to adjusting the steering box .
Old Jan 12, 2002 | 10:33 AM
Phillip Guidry's Avatar
Phillip Guidry
Yeah, take Paul's advise first! I sent my truck for alignment, had all new tie rods put on by my request, I even kinda remembered asking him not to adjust the box because of stories I have heard about having to drive with 2 hands after this was done due to not returning to center on its own. Well sure enough, went by to pickup my truck, they said "its ready to go BUT there is still some slack in the box that we can't seem to take up, even after adjusting it several times, you'll just have to live with it." I expressed my concern for them adjusting the box without checking something else first. None the less, as I drove away I wasn't too happy with the way it drove. I thought I could get used to it over the weekend, but not. The steering wheel did not want to return to center after a turn.Well, I searched for the "slack" they couldn't get out by adjusting the box, it was the intermediate shaft between the column and the box. The upper joint was good, the lower joint was good, the problem was where the shaft telescopes in the middle....all kinda slack. After some trick ball peening, the slack was gone in that area. Test drive...better feel in the wheel...still trouble to return to center. I had to loosen the box several times over the course of several weeks to get things back to normal.
Phil
Old Jan 12, 2002 | 10:44 AM
canadianfordman's Avatar
canadianfordman
snaponprofile
Apr 28, 2011 02:27 PM
ron9
Sep 29, 2007 07:04 PM
Jtown150
1997 - 2003 F150
Mar 9, 2004 11:59 PM
Trader Bob
Mar 16, 2003 11:16 PM
