Drove a 2017 Today!
Old Aug 24, 2016 | 12:02 AM
wb6anp's Avatar
wb6anp
Usually the tire manufacturer has a psi vs weight chart.
Old Aug 24, 2016 | 12:23 AM
Blk04Snake's Avatar
Blk04Snake
That should take care of the liability issues then. Wouldn't they be just as liable if the truck says 80psi, you pump that 65psi tire up to that pressure then the tire fails?
Old Aug 24, 2016 | 12:26 AM
wb6anp's Avatar
wb6anp
Old Aug 24, 2016 | 05:16 AM
System's Avatar
System
Prolocutor
Originally Posted by Blk04Snake
Where might these instructions be? I know that my 2010 F250 had rear PSI of 65 but the F350 that was otherwise exact same truck was 80psi and I wish it could have been turned down. I will want to lower it because the likely Toyo M/T that I will be adding on custom wheels have a max pressure of 65psi.
You'll have to do some searching in the forums. It was over 4 years ago now that mine was done. I do remember it was very easy though. Maybe 3-4 steps after they plug into your truck. Less than a minute job.
As to liability, the scenario is this. If they lower the alarm threshold and you tow or load heavy while aired down you could have a blowout and have an accident without the low pressure alert ever going off. We live in a litigious country and if people can sue, they will...
thelonius
Aug 22, 2017 12:25 AM
RedFish_n
6.7L Power Stroke Diesel
27
May 22, 2014 07:38 AM
craustin
6.4L Power Stroke Diesel
Jun 12, 2007 07:45 PM
Sparty
17
Feb 27, 2007 10:41 AM
defrag
Car/truck Buying Advice
Mar 29, 2003 08:48 PM
