Bellhousing Question
Old Aug 21, 2016 | 05:22 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I stand corrected by NumberDummy.
TOD doesn't stand a chance behind a healthy 460.
Old Aug 21, 2016 | 05:57 PM
dnkensinger's Avatar
dnkensinger
Originally Posted by ArdWrknTrk
They are entirely riveted in my truck Chris....
There are *no* "mid '60s" 385 series engines.
They started in 1968.
385 & 335 series engines are the only ones to use this pattern
So, you have a 1950's gearbox bolted to an engine pattern that didn't start until the mid '60s?
'Cause it wasn't until late 1964 ('65 Model Year) that the 'Windsor' pattern came into being.
I guess when I said mid 60's, I was just guessing. I don't have anything as of right now, but am actively looking and was just wondering if I could go as far back as '68/9.
Old Aug 21, 2016 | 05:59 PM
dnkensinger
RTS TS-OD = 1984/89 F150 2WD/4WD & Bronco 300/302/351W
Both the RTS and the RUG SR-OD (Single Rail 4 Speed O/D) that preceded it are "weak sisters."
One speed shift, you can kiss the little darlins' good bye.
So I guess after reading this that the best thing I can do is source a T-19? Will these bolt right in, and by that I mean does the crossmember have to be modified, will my current gear shift lever work?
I am DUMB DUMB DUMB when it comes to transmissions. It's one thing I could never get in to. I guess now I'm kicking myself for that.
Old Aug 21, 2016 | 06:13 PM
82F100SWB's Avatar
82F100SWB
A diesel bell is not a 460 bell, same casting, drilled differently, only the top 2 holes line up. On a diesel the starter bolts to the adapter plate, not the bellhousing like a gas truck.
As for the Clark transmission thing, I recall seeing that in the decoders in Chiltons books, yet I have never actually seen such a thing.
You will need to change driveshafts completley, 2wd ZF's are fixed yoke output, so you you need a slip shaft, a 4wd with a fixed yoke could be a possible donor for shaft parts.
The only hitch with an early engine, is that they are internal balance, and the ZF uses a 12" clutch. You need to have the ZF flywheel zero balanced or a zero balanced one drilled to suit the pressure plate.
Old Aug 21, 2016 | 06:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No!
Current gear shift lever...
Old Aug 21, 2016 | 06:39 PM
dnkensinger
How about the hole on the tunnel. Can I keep that the same? Crossmember?
Old Aug 21, 2016 | 06:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
'60's engines were meant to run on 98 octane leaded premium.
So forget trying 10.5:1 iron heads on pump gas.
Blocks marked D9TE will be external balance.
These will have D3VE heads.
Maybe 8:1, but they will run on fuel you can buy.
dnkensinger
I'm looking at the parts illustrations for the gearshift mechanisms but the descriptors for the various transmissions don't coincide with what I'm used to hearing them called. In other words, I don't see an illustration for the T-19. Is it called something else?
Old Aug 21, 2016 | 06:51 PM
dnkensinger
These wiil have D3VE heads.
Dealing with this issue right now on my '69 Lincoln. Just started running 99 octane gas and I have to retune the engine...
Old Aug 21, 2016 | 06:55 PM
dnkensinger
I suppose I should just stick to hunting down an engine of the correct era. Probably will make life a whole lot easier.
Old Aug 21, 2016 | 06:59 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can use a 'normal' crossmember with a T19 gearbox.
You only have to move it for a Zf.
The 'normal' transmission hump will clear the B/W gearboxes.
Old Aug 21, 2016 | 07:11 PM
Franklin2's Avatar
Franklin2
Finding a donor 460 truck would make your life the easiest. In fact, using the donor frame would make it really easy, since it will have the dent in the crossmember for the 460 oil filter. The donor will also have the 460 with the proper oil filter adapter for clearance, the correct crossmembers, bellhousing, driveshafts, fuel system, heavier frame, larger rearend to handle the 460, heavier frontend to handle the weight of the 460, etc.
Old Aug 21, 2016 | 07:19 PM
  #28
NumberDummy
No.
460 not available w/a M/T (or 4WD) until 1983.
460: 1968/78 Lincoln/Continental Marks / 1972/76 Thunderbird / 1973/76 F100 / 1973/78 Ford/Merc Passenger Cars / 1973/79 F250/350 / 1975/79 F150 / 1975/2014 E250/350 / 1983/97 F250/350.
Some 1978 Lincoln/Continental Mark V came with the 400.
Here's the illustration of the T-19 from the 1980/89 Ford Light Truck Parts Catalog, available on a C/D from hipoparts.com
Old Aug 21, 2016 | 07:28 PM
  #29
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
look for a M4HD under a 250-350 truck with the 460..
Mine was marked 13-09-065-911, if that helps at all.
Old Aug 21, 2016 | 07:31 PM
  #30
NumberDummy
T-19 pic in post #28.
