Little help
Old Aug 19, 2016 | 09:30 AM
Kidd1234's Avatar
Kidd1234
Little help
Wondering if there is a difference in fuel pressure when you add the Ats turbo kit to a 7.3idi? I'm trying to figure out if the injector lines need to be higher pressure rated or not. Thanks
Old Aug 19, 2016 | 10:36 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Welcome to FTE!
No ...
-Enjoy
fh : )_~
Old Aug 19, 2016 | 02:52 PM
genscripter's Avatar
genscripter
Old Aug 19, 2016 | 04:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome. as already said, you are fine with the stock lines. turning up the fuel delivery after adding a turbo does not increase pressure, just fuel volume.
Old Aug 19, 2016 | 07:31 PM
Macrobb's Avatar
Macrobb
To explain further: the IP produces fuel at between 1400 and 1800 PSI. The pressure depends on when the injector spring is overcome and the injector opens; adding more fuel just keeps the injector open longer but will not increase the pressure.
If you are worried about the extra pressure from the boost(as you might when running a carburettor and turbo on a gas engine), you don't have to worry because the injector pressure is so much higher; it won't make any difference.
berick
Nov 19, 2016 08:28 PM
dhag911
21
Jun 5, 2014 01:30 AM
DIESELMAN3500
May 17, 2007 10:48 AM
RacinNdrummin
4 Cylinder Engines
Feb 5, 2005 11:31 AM
powerstroked162
Apr 10, 2004 07:04 AM
