2017 SD Towing Guides
Old Aug 18, 2016 | 11:52 PM
pstroke's Avatar
pstroke
I have been keeping a lookout for the release of this information and it has finally arrived. Now all I need is a VIN and then a truck!
http://www.fleet.ford.com/resources/...Fleet_Aug4.pdf
Old Aug 19, 2016 | 07:03 AM
4dogdoc's Avatar
4dogdoc
This guide does say "preliminary" with the final version to be published next month.
Old Aug 19, 2016 | 08:04 AM
SwensonBarrettBunch's Avatar
SwensonBarrettBunch
Did anyone notice that the 925 Torque is back at 1600 rpm in the towing guide?
Old Aug 19, 2016 | 09:39 AM
Fowlthing's Avatar
Fowlthing
Help me understand the lower towing capacity for the 350 versus the 250 per the guide. short bed 4x4 with diesel engine???? should be the other way around?
Old Aug 19, 2016 | 10:08 AM
4dogdoc's Avatar
4dogdoc
Maybe I'm missing something, but under the spec section on the Ford website under payload options, it list the max GVWR for a 350 srw 4x4 as 11,500, but on the build & price section the highest GVWR package is 11,400 for a 350 srw 4x4???????????? Just misprints, or what?
Old Aug 19, 2016 | 10:26 AM
Rasalas's Avatar
Rasalas
11,400 is a downgrade for documentation only, as are the other lesser packages. Some prefer to register at a lower weight for monetary reasons in their individual states.
Old Aug 19, 2016 | 11:14 AM
4dogdoc's Avatar
4dogdoc
Okay, but the 11,400 GVWR package on the build site is what I need for max payload & max towing, correct?
Old Aug 19, 2016 | 11:15 AM
SwensonBarrettBunch
No. You need the camper package for the max towing and payload according to my dealer
Old Aug 19, 2016 | 11:20 AM
Rasalas's Avatar
Rasalas
Let me say it simpler: the 11,400 GVR package is a down grade.
Old Aug 19, 2016 | 11:21 AM
4dogdoc's Avatar
4dogdoc
On the build site it only lists upgraded front springs with the camper package. Does it automatically bump you up to or default to the 11,400 package too?
Old Aug 19, 2016 | 11:24 AM
Rasalas's Avatar
Rasalas
The camper package does not change the rated 11,500 lb on the F-350. It increases the front springs to maximum in order to handle the offset load of a slide in camper. As far as the rating itself goes, nothing changes.
SwensonBarrettBunch
It gives you the highest GCWR. As stated, the 11,400 is a downgrade
Old Aug 19, 2016 | 11:48 AM
Rasalas's Avatar
Rasalas
I think your dealer is referring to the F250 with a camper package. The package adds the second spring pack to the rear, (helper springs) and upgrades the front springs up to 2 levels. The rating for the truck does not change even though it is more capable. The F250 SRW rating is at 10,000 lbs unless a package which lowers the rating is selected. The F350 SRW is rated at 11,500 unless a package which lowers the rating is selected. Choosing a lower rating does not change anything physical about the truck.
Old Aug 19, 2016 | 12:00 PM
SwensonBarrettBunch
If you look at the towing guide above, there are different GCWR ratings. The F350 SRW has a MAX of 28,700. That is the total weight of the truck and trailer combined. It does not change the GVWR of 11,500. My dealer said that the camper package will max out the GCWR
Old Aug 19, 2016 | 12:05 PM
SwensonBarrettBunch
The F250 with the trailer tow package is only rated to 25,700
