Rear End Backlash Adjustment
Old Dec 6, 2004 | 01:53 PM
ParisDakar's Avatar
ParisDakar
I believe I've finally located the source of my clunky drive line. It appears the ring gear has a lot more backlash than the .008 to .015 it should have. It's been this way since it was new, and hasn't gotten worse over time. My question is, after 93k miles, is it possible to now readjust the rear end properly or have the ring and pinion "worn in" to each other too much?
Old Dec 10, 2004 | 09:28 PM
NWBronco's Avatar
NWBronco
93k on the gears? How do they look. If in great shape, then they can be adjusted. You'll have to break them in again, just like new gears. If they look bad, replace 'em.
Bob K.
Old Dec 10, 2004 | 10:49 PM
Mojave2k's Avatar
Mojave2k
Don't mess with gears that have seated in, they will howl at the least. Be sure that your pinion and carrier bearings are good, and change the oil. If it is quiet going down the road I wouldn't mess with them, (If it ain't broke, don't fix it). If you want to tighten things up, then put in a new ring and pinion set, new bearings and if you plan to keep the truck a long time, a positraction carrier. The reason for the posi is that it preloads the gears and takes out the "play" that open carriers have.
aidandj
Nov 25, 2015 02:40 PM
Ron94150
Aug 28, 2015 09:35 PM
89ford73
Nov 4, 2011 03:28 PM
rb76543
Jun 20, 2010 04:59 AM
rwjr
Jul 29, 2009 10:34 PM
